BigNick73
So I started a pen tonight, was going to be a closed end churchill made with a blue burl/acrylic blank. I painted the tubes white and I can see the tube. This wouldn't be a problem with a normal kit as the body and cap would match, but now I got a pen body that's half light blue and half dark blue. The light half being the thin part against the white tube and the dark being the thicker end that I only used a 7mm bit on to make room for the converter.
Is there a way to handle these slightly translucent blanks? Full length tubes?
