Closed End Pen Help!
Dr Robert
Kennett Square, PA 19348
I would like to start making closed end pens but have zero experience. I have been researching various techniques on line but many seem very technical and confusing. Any suggestions for a nice, concise technique along with the necessary armamentarium, ie holding mandrels etc!?
Dieseldoc
Livermore, Ca 94550
Hey Doc:
Just under the IAP logo, left side.
Go to forms, Library, advance pens section and you will find lots of good proven info.
Good luck on you closed ends turning.
Dieseldoc
mark james
IAP Collection, Curator
Medina, Ohio
If you have a collet chuck set, or a drill chuck with drawbar for your headstock- Buy a set of punch presses (Harbor Freight, etc: https://www.harborfreight.com/hand-tools/punches/28-piece-transfer-punch-set-3577.html), grind a flat slot on whatever OD you need. Use a small nail ground to approximate size, and you can have fun with closed ends very economically. (May need some blue tape to get the nail to fit the slotted punch bar snugly!).
The benefit of the transfer set is that you can have every conceivable (well, almost) size needed for closed end turnings, and the transfers are still good for their intended purpose.
its_virgil
Wichita Falls, TX, USA.
Go to http://redriverpens.com/articles.htm and look at article #13 and #14. They should get you started. You do not really need any special tooling to make closed end pens BUT new tools are nice. I am not a fan of the PSI mandrel with the rubber tube mentioned above but hey, you and others may find it acceptable. Good luck. It is fun to learn a new skill.
Do a good turn daily!
Don
