Clip thickness - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Advanced Pen Making
  Forgot Password
Advanced Pen Making Kit-less construction; designs and challenges beyond those normally associated with kit pens.
Welcome to penturners.org!
Reply
Old 04-16-2019, 11:17 AM   #1 (permalink)
Muggsy1776's Avatar
Photos: 3
Default Clip thickness
Iíve started making my first kit-less fountain pen and I want to try my hand at making the clip. Iím down to making the clip and instead of altering an existing one I want to start with making my own. My question is what thickness of metal should I use? Does it depend on the material?
Muggsy1776 is offline   Reply With Quote Top
Old 04-16-2019, 03:57 PM   #2 (permalink)
Photos: 2
Default
I am currently in the same boat. I don't think I've got the material or method down pat 100%, but the material and the tools at your disposal are big determining factors.
A lot of clip makes I've seen use either nickel silver or brass. They are relatively soft and therefore must be thicker to avoid getting bent. Steel is stronger, but also makes it more difficult to finesse into the size/shape you want. It still may also be susceptible to getting bent without certain a certain variety of steel and hardening procedures.
I played around with some 20 gauge 304 stainless and got something like this:
Not perfect, but I'm getting there. I ordered some samples of nickel silver to try and we'll see how that goes.
hokie is offline   Reply With Quote Top
Old 04-16-2019, 05:38 PM   #3 (permalink)
Photos: 0
Default
I would start with 1/16. I believe that Mike Redburn has mentioned that thickness in the past. I have used it for bronze based on John Albert's recommendation and I believe that's what he uses for bronze and nickel silver.
If it's too thick you can always file it down; if it's not thick enough, you're sunk.
Bill
bmachin is offline   Reply With Quote Top
Advertisement
Old 04-16-2019, 06:36 PM   #4 (permalink)
Ironwood's Avatar
Photos: 14
Default
I make mine out of large stainless hose clamps. The stainless strap is about 0.7-0.8mm thick. This works for me.
__________________
Brad
Ironwood is offline   Reply With Quote Top
Old 04-16-2019, 07:18 PM   #5 (permalink)
TG Design's Avatar
Photos: 0
Default
I made one out of 0.042Ē (1.07mm) titanium. I had to heat it to get the 90deg bend at the top and clip end. I then bead blasted it for the matte finish, Ti also polishes real nice.
TG Design is offline   Reply With Quote Top
Old 04-16-2019, 09:35 PM   #6 (permalink)
TonyL's Avatar
Photos: 6
Default
All very nice! How do you folks fasten them so they hold firm please?
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is online now   Reply With Quote Top
Old 04-17-2019, 05:31 AM   #7 (permalink)
TG Design's Avatar
Photos: 0
Default
Integrating a clip is the hardest part of cap design. I used a socket cap bolt and machined a groove to capture my clip. img_3732.jpg
Old 04-17-2019, 06:02 AM   #8 (permalink)
TonyL's Avatar
Photos: 6
Default
Thank you. That's outside of my league. Well done!
__________________
Peace,
Tony
Old 04-17-2019, 06:54 AM   #9 (permalink)
darrin1200's Avatar
Photos: 21
Default
I just ordered some 510 Bronz at .04 and .09, Nickel-Silver at .06 and SS-301 full Hard at .050”. I also ordered some silversolder to try my hand at that type of connection.
__________________
Darrin
Timber Elegance ~ Handcrafted Writing Instruments
My Etsy Store
darrin1200 is offline   Reply With Quote Top
Old 04-17-2019, 01:31 PM   #10 (permalink)
Photos: 0
Default
Tony,
There's an old series of videos by a guy named Steve4948. I've linked to the one of him making a cap and attaching a clip here:
https://www.youtube.com/watch?v=sKM9WWYob_E
This guy is really interesting and when disaster strikes, you see it. Some of his Toastmaster speeches are also quite humorous. He also has videos on making a mandrel on a wood lathe and making a kitless pen on a wood lathe. He's not slick, but you can learn a lot.
There is also a library article on the same technique here:
http://content.penturners.org/librar...al_options.pdf
If you have a clip with a large enough OD you can leave the it exposed and a bit proud. Just make sure that the male thread of your finial is a very close fit to the ID of the clip to keep it fro moving around. Screw it down tight and use some sort of thread locker/sealant to keep it from coming unscrewed. DAMHIK!
Bill
Related Content
Reply
Bookmarks
Tags
clip
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
