Click Mechanism Faulty
Oklahoma City
Hey folks I need help!
I have a problem with the click mechanisms from Rich Greenwald's site! They seem to be catching and I am unsure as to how to fix that problem. I've checked all of the ways the refill could be catching but it doesn't seem like it's the refill.
And whenever I use the mech by itself it still catches.
Here's the mech: Push Button Mechanisms [10179] : Richard L. Greenwald, LLC, Pens, Pens Parts and Photographs
Any insight would be helpful!
Thanks,
Michael
BSea
Little Rock, Arkansas
That's not been my experienced. I've never had a bad one. But I know that doesn't help you much. About the only thing I can think besides the mechanism is the spring causing a problem. Have you contacted Richard?
Oklahoma City
Perhaps. I will attempt replacing springs tonight. My problem is that it catches even when it is by itself.
I have not yet, but I will contact him as well.
Michael
TonyL
Georgia
I have a similar experience with the CSUSA clicker. I can make 6 in a row without a problem, then the next 3 will stick.
Brooks803
Aiken, South Carolina
Crap! Sorry Michael! I forgot to send you those pics. Something came up today that took me away from the "office".
For the mechs...if they're catching just by themselves there might be a burr on the inside. Mike Redburn did a write up on an alteration he did to them and he showed how he took it apart I believe. Let me see if I can find it and get the link here.
Oklahoma City
Ah no worries! Send 'em tomorrow?
I'll do some studying. Thanks Jonathan!
BSea
In most cases, the spring is the culprit here. The spring should have a larger end that goes into the nib while the more tapered end goes toward the refill. If they are reversed, the refill will bind. I have seen a case where the spring didn't have a larger end. In that case you could try to expand the spring on one end, or buy some replacement springs. I think Richard Greenwald sells the springs, but I'm not positive.
It could also be that the plating is too thick at the point of the nib. In that case, a small drill bit may be needed to slightly expand the hole so the refill doesn't bind in the hole.
Hope this helps.
Brooks803
Promise!
Oklahoma City
Hope this helps.
I thought the refill was binding so I drilled to attempt to fix that but it doesn't seem like that is the issue. I will get back to you upon more investigation -- I will probably pull the click mech apart tomorrow.
Oklahoma City
So I tried playing with springs today. I used three different springs all with the correct taper. One was a kit spring from an old sierra kit. The second was from one of Constant's Stainless kits. The third was brand new from Richard's website. The mech stuck with the same consistency each time.
I will pull it apart when I get time. My job has got me tied up currently.
Michael
TonyL
Georgia
I have moved that spring in all directions well, just two LOL)..even tried different springs. I wish I can say I have been more than 70% successful.
mredburn
IAP Activities Manager
Staff member
Fort Myers FL
THere is a 1mm ball that travels around in a groove in the outer casing and in the groove in the shaft of the click mechanism. The parts are brass plated with nickle or chrome and you may have a bur or bad spot created by the plating. It could be dirt or flecks plating that somehow are stuck inside. Using a toothpick with a tiny dab of grease on it helps to hold the ball. If the ball it self is bad, maybe it has a flat spot or is deformed in any way I have extras. (or if you loose it)
