brass pens
franklin co. mississippi
i make pens out of 300 win mag shells
start out with 2 300 mag cass an 1. 6.5x55 swede case
drill out the back of the mag
I use a flaring tool to hold it while i drill
lay it in a 90 degree jig, to keep it lined up,
I put the swede case in the neck of the mag. i will cut it off later
just using the neck as a bushing
solder it up
into the drill, buff it shiney using 0000 steel wool
then , cut the swede excess off, put the pen inside and its done
