Pressure Pot Caddy feedback
BeeAMaker
Elkhart IN, USA
Not sure where to put this post, but since I will be asking for some feedback, I figured this would be the spot.
A lot of you have ordered my Pressure Pot Caddy or the Pressure Pot Caddy V2 and have time to use it for a while. I was hoping I could get some feed back on it from those that have used it.
Just some questions off the top of my head,
1. How do you like it?
2. What happen to it if you had a resin spill?
3. Value for the money?
4. Too many holes in the V2?
5. Any other suggestions you can make or issues you have had with it.
I am also looking at making a version out of HDPE 1/4" sheet. This would be so resins hopefully peel right off. However it would make the Caddy more expensive, about $35 each (V2 version) Would it be worth it?
It's been a while since I have been able to turn, so hopefully again soon!
Thanks for any feedback!
:biggrin:
eharri446
Marietta, GA
I have not ordered one from you yet, however, I would be interested in the V2 in HDPE since I am prone to spilling.
However, from what I see on your web site, the caddy looks stable and well designed.
If you get one in HDPE PM me with the information and I will get your money to you. Even at $35 for the HDPE version, yours is one of the lesser priced ones that I have found.
BillyBoy63
Heyworth IL
Pressure pot caddy V2
I bought the V2 caddy have not used it yet just getting started in casting world
I think the design is great it should work great like the 2 part design were you can use a mold or use the tube style molds.
getting ready to order some tubes and plugs you need to get busy and make some more of the four peace sets you are only showing 1 in stock
here is another idea
make a bigger package deal and maybe throw in a free plug or something like that
BillyBoy63 :biggrin:
Fuquay Varina, NC
PLEASE make it out of HDPE... I'll buy another... I use your caddy for my production casting and I've made probably 400 blanks since buying it. Each cast I spend about 5-10 minutes clearing off resin for the next cast. I also have to spray expensive mold release on it fairly often to keep the resin from becoming one with the holes.
From a design perspective, it works great for me... In fact I was going to go and get some sheet HDPE and just cut out matching pieces on my bandsaw because I spend so much time removing resin that drips down the tubes.
BeeAMaker
Elkhart IN, USA
Thanks everyone for the feed back!
I'll get some HDPE and give it a go. I should have some proto's cut by next week.
I'll also get some more stoppers made up!
Thanks!
PatrickR
Rural America
Ive used mine about a dozen times and love it.
I'm not doing any vertical casting currently but having the option is nice.
I have not had any spills so far but don't think I'd want to pay almost double for HDPE. If spills were a problem I'd protect it with some tape. 1/4" HDPE sounds too flexible to me
Fuquay Varina, NC
Thanks!
I could probably use some stoppers as backups as well... Let me know when you get those prototypes done. All my vertical casting is done with the molds already in the caddy so obviously there is some dripping and spillage. I dont' think the sides/top need to be HDPE but the 2 trays with the holes in them should definitely be. Bottom... I could go either way but HDPE would at least make it easy to keep clean.
JHolliman
La Conner, Wa
I have been using mine and I Love it!, But I agree Making it out of HDPE would be awesome and I would be interested in that version as well!
BeeAMaker
Elkhart IN, USA
Sorry for not getting back sooner, I'm a bit behind.
HDPE laser cut better than I expected, they turned out great I think.
I will be taking pre-orders next week and ship by the end of the following week.
They take a bit more time to cut, I haven't settled on a price yet, right around $35 - $40 per kit. Individual shelves will be available also and will work with the current melamine ones. I'll post a link here when it's.
I also have more rubber stoppers in stock ;)
Note: I think I would use them with the textured side down, smooth side up. Would be easier for spills to peel off. It just don't look as pretty
Bob in SF
San Francisco
Glenn - Your original Caddy with blank shelves works perfectly for me!
I've cut a stack of non-stick parchment paper "liners" to protect the shelves.
I've just pre-ordered 2 of your HDPE blank shelves.
Warm regards, and keep up the fine work.
Gratefully, Bob
BeeAMaker
Elkhart IN, USA
Gratefully, Bob
Thanks! Your order will ship Monday, I need to remove that Pre-Order notice from the store site.
