Plastic Polish Comparison
TonyL
Georgia
Here's what I compared:
HUTS High Gloss, Novus 2, One-Step (which is the same as Flitz per Olaf of Flitz), Meguiers 105, Meguires 205.
All turned using carbide, finished to 12,000 MM, viewed under a 10X LED light.
Meguires 105, did the best job and removing fine radial scratches. I have not found any to live-up to their claims of "no sanding needed after 400 or 600 grit" I did try this, as well, as sanding up to each progressive grit to 2,000.
I may try the Doctor's 3 step process, once I get rid of all of this polish :biggrin:
This is just my experience.
My best process is MM to 12000, Meguires 105, then 205, followed by Rejex "wax" for protection. I know there are many excellent processes out there. If I live long enough, I may try them all. LOL
TonyL
Georgia
I enjoy the experimenting and the excitement of finding something better. I also started using Meguire's first, two weeks after I starting turning acrylic (I used a buffy wheel before that) and knew nothing about plastic polishes - I just happen to have Meguires in my garage for auto detailing. Recently, while browsing through the catalogs, I read the manufacturer/distriutors' claims of these other polishes. I thought I would try them and could possibly eliminate some sanding. With Meguire's, I still have to sand through 4,000. What do you like Bill?
Russknan
Nanuet, NY
Thanks, Tony for doing the "leg work" for the rest of us. I really hope you do manage to try the 3 step Dr's Polish. Would love to know how that compares under the same conditions. So far, I like it. Russ
Mack C.
Passed Away Sep 29, 2018
Brooklin, ON Canada
Fine radial scratches are best removed with longitudinal sanding, without the lathe spinning.
I also like Meguires PlastX.
wwneko
APO, AP
Tony, How did the other's rate? Maybe rate them from coarsest to finest, probably not the proper terms for polishes.
TonyL
Georgia
My unscientific experience was this:
From most "scratch removal" to least
1. Meguires 105
2. Meguires 205, Novus, HUTS - tied
3. One-Step
While I do sanding length-wise with the lathe off, I can't say it makes a difference that I can see.
Skie_M
Lawton, Ok
I like Meguiar's PlastX also ...
"Diminishing Micro-Abrasive Technology provides powerful yet safe cleaning/polishing action to remove:
* Light Oxidiation
* Sains and Contaminants
* Fine Scratches
This easy to use rich gel formula contains vital conditioning oils, which restore optical clarity to clear plastics and beautifies opaque plastics. Highly water resistant polymers provide long-lasting durable protection. PlastX is non-toxic and does not contain any harsh solvents.
NOTE: NOT FOR USE ON PAINTED SURFACES."
(off the back of the bottle ...)
I started using this when I read about the One-Step plastic polish over at the PSI website and decided to see if this would work. One-Step also touts a "Diminishing Micro-Abrasive Technology" formula, and I can't help but wonder if they're both made by the same company. I only bought the bottle 2 years ago in order to clear the yellowish haze off my headlights so that I could see while driving at night. I have to say, this stuff is magic on a CA finish or acrylic pen barrels alike... It's like my pens have a glass finish. Ultra-smooth, with no visible scratches at all. Everybody who picks up one of my pens just can't help but marvel at how I could get a finish that perfect.
TonyL
Georgia
This is great info. When I called Meguiar's, they did recommed PlastX (which I have). And they didn't want me to use 105 and 205 on plastic (CA, acrylic, PR, etc.). However, remember, Meguiars makes products for car, boats, etc. surface....not pens. I think 105 and 205 are too aggressive for Meguiars to recommend for plastics..they also sell a product for plastic as we are all aware of.
I learned from PSI and Flitz that One Step and Flitz are the same, just private labeled (I wish I saved the email). Here's what is funny...according to Flitz (per his email to me), Flitz doesn't remove fine scratches (or any scratches). Who can make sense of this stuff?
I think it comes down to finding something that produces a finish that you and your pen recipients like, and to a standard and level of effort that you one finds acceptable (I am content with no visible scratches under a 10X loop).
I just spent over 200 on a bunch of Caswell stuff for CA finishing. I really don't like introducing moisture to a CA finish which wet sanding does. I tried all of the drying sanding and steel wool sanding techniques mentioned here, and I can't achieve what the other turners achieve using those methods. Although,I have seen some of their work and it is outstanding.
That's what makes this hobby frustra....., I mean fun ! :).
Thanks again for sharing and continued success with your technique!
chartle
Pgh, PA
Thats for the testing, much better than what I did. Went to Wal Mart's automotive section and just picked what ever looked good.
I bought Meguiar's PlastX.
BKelley
Tucker, Georgia, 30084
Tony
Next time you are in Woodcraft pick up a tube of Simichrome. I've used it for years with great results. I sand with 400, 600, 1000, 1500, 2000, 3000 and 5000 and finish off with Simichrome. It is a little pricey, but well worth it.
Ben y
kruzzer
Fort Myers, Fl, USA.
Tony,
I have been using Nu Finish 'scratch doctor/scratch remover with very good results. It's also an automotive product.
On my vehicles I pretty much stick to Meguiar products so I'll have to give your finding a try. thanks for doing all that research
Charlie_W
Sterling, VA USA
Tony, thanks for getting this discussion started.
I am however surprised that no one has mentioned the plastic polish that Barry Gross sells. I have been using it for years. Also, I do not turn the lathe on when using this. I apply longitudinally with my finger while rotating the hand wheel by hand. I allow the polish to dry to a haze and then, by hand, buff it off still longitudinally using a piece of clean T shirt material. When I get to the point of polish, I do not want to still be putting rotational scratches on the pen..no matter how fine they may be.
Additionally, there has been no mention of buffing afterwards. Likewise, I use the acrylic buffing wheels by Barry Gross which use the blue rouge on one wheel and then a clean wheel. Again, using these wheels, I buff with the length of the pen. Not in a rotating direction. After this, just a hand wipe with another piece of clean T shirt wiping lengthwise to remove any remaining residue.
I don't have a loupe but it looks top notch to me. A piece of polished black acrylic in direct sunlight will show up any scratches in your process.
I am not a "loupey" guy.
Carry on!
