New lathe advice - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Product Testing & Review
  Forgot Password
Product Testing & Review Member testing & reviews of equipment, tools, kits, parts, and supplies.
Welcome to penturners.org!
Reply
Old 03-11-2019, 01:41 PM   #1 (permalink)
Photos: 0
Default New lathe advice
I am looking for a new lathe, I am new to turning and donít want to spend an arm and a leg but I donít want to grow out of what I buy either. I am looking at at 12in Rikon 70-1280vs for 500ish and the Nova Comet 2 with a chuck for 600is, and the Jet JWL-1221sp for 419. Iíve had people say donít buy Rikon and people say donít buy Nova, amd a few say with Jet your buying the name. I just want to be able to turn 12in bowls down to pens and rings. Is the variable speed worth $100 HELP lol
mkrevda is offline   Reply With Quote Top
Old 03-11-2019, 02:12 PM   #2 (permalink)
monophoto's Avatar
Photos: 0
Default
There are many turners who happily use treadle-powered spring-pole lathes. And I've even seen a belt-driven, waterwheel-powered lathe.
But most of us prefer electrically-operated lathes. They are just more convenient.
Variable speed is another form of convenience. It's not essential, but most of us prefer the convenience of being able to quickly vary the speed of the lathe to the nature of the work being done. Higher speed produces smoother cuts and is important on thin spindles (such as pens), but sanding requires lower speeds to avoid overheating the timber, etc.
The three lathes you mentioned are all good - but the JWL-1221sp is NOT a variable speed lathe - you have to swap pulleys to change speed.
So its up to you - what kind of work do you expect to be doing, and how much convenience to you want (said differently, how much inconvenience are you willing to put up with)?
You seem to be focusing on so-called 'midi-lathes' - machines with a 12" swing and a bed length of about 18". There are brands that you haven't mentioned - Laguna and Turncrafter for example. These are also good. The criticism that with Jet, you are paying for a name could be said of any of them.
__________________
Louie
http://monophoto.deviantart.com
Instagram: @louie_powell_photo
monophoto is offline   Reply With Quote Top
Old 03-11-2019, 03:39 PM   #3 (permalink)
Photos: 0
Default
That is awesomely helpful. I am focusing on the 12x18 size for space reasons, and the three that I mentioned are in the $500 range I am hoping to stay with in. I never looked at laguna or turncrafter on the assumption that they were far more expensive, but I will take a look. I truly appreciate your help
Advertisement
Old 03-11-2019, 03:50 PM   #4 (permalink)
Charlie_W's Avatar
Photos: 3
Default
In my experience, go for the variable speed drive if at all possible....you wonít regret it later.
Also, compare the horsepower of these lathes as some of the midi lathes are now 3/4 HP instead of 1 HP. Compare warranties.
I will say that the Comet is lighter to carry to shows and demonstrating...but myself and others find the plastic lock levers especially on the tailstock to be somewhat lacking. The tailstock will still creep when locked down.
Note that a 12Ē Lathe with this type of motor will turn a 12Ē Bowl if you take light cuts. At 12Ē, the torque and power of these motors are struggling to do the job. Horsepower ratings can vary. A better picture is to check the amperage.....more amps=more power.
Good luck!
__________________
Charlie W.
Charlie_W is offline   Reply With Quote Top
Old 03-11-2019, 04:13 PM   #5 (permalink)
Photos: 0
Default
As a new owner of the Nova Comet II I will say if you plan to plug into a GFI this lathe can have issues tripping GFI, I just got off the phone with Teknatool technical support and he acknowledged it can be an issue.
indytruks138 is offline   Reply With Quote Top
Old 03-11-2019, 04:23 PM   #6 (permalink)
JimB's Avatar
Photos: 11
Default
In addition, you say you want to turn 12” bowls... a lathe with a 12” swing is not going to give you a 12” bowl because you need to account for the space the banjo takes and the wood you will remove. You also need to consider if the lathe weight, motor power and slowest speed will allow for turning out of balance blanks.
Personally I would spend the money and get VS. IMO Jet quality is better than the other lathes listed but I haven’t seen the new Laguna 1216 yet but if is anything like its big brother the Laguna 1836 it will give the Jet serious competition.
__________________
Jim
West Henrietta, NY
JimB is offline   Reply With Quote Top
Old 03-11-2019, 05:33 PM   #7 (permalink)
magpens's Avatar
Photos: 75
Default
I would say it is well worth $100 to have the variable speed.
Who wants to stop and change belt position when you are in the middle of turning something and find that the speed is not optimal ?
Check that the VS will go down to very low like 50 RPM ... that is very useful for applying finishes like CA so that you are not centrifugally spraying your shop walls and ceiling (and yourself).
__________________
Mal
Kids rule the world !!! .... eventually if not already !
magpens is offline   Reply With Quote Top
Old 03-11-2019, 06:08 PM   #8 (permalink)
monophoto's Avatar
Photos: 0
Default
One of the regulars on this board suggested an approach to evaluating lathe purchases that I think is really profound.
Suppose you buy a lathe for $XXX, and it dies on the day that the warranty expires. If it had died one day earlier, you could have gotten a free replacement. But because of the timing, you now have to decide whether you like that lathe enough to pay for a repair (or replacement). And if you decide that you don't like it, then the annualized cost of learning that lesson is
Cost = $XXX / term of the warranty
On that basis, a $450 lathe with a 3 year warranty is equivalent to a $750 lathe with a 5 year warranty.
So the bottom line is that you have to look at price, and you have to think about warranty, but you also need to look at the features, and ultimately make a decision based on the total package.
__________________
Louie
Old 03-11-2019, 07:23 PM   #9 (permalink)
Photos: 1
Default
I vote for VS...you will not regret the extra cost. It is a feature you will likely use regularly, for the life of your new lathe (unless you opt for the less expensive non-VS). If you chose the later, you will probably regret that decision for the life of your new lathe. You might possibly even buy another new lathe WITH VS.
One man's opinion...
__________________
Steve Guzy
SteveG is offline   Reply With Quote Top
Old 03-11-2019, 09:34 PM   #10 (permalink)
KLJ
Photos: 32
Default
I think variable speed is well worth 100. I also recommend by as big as space and money will allow.
KLJ is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
