Carl Fisher
I had an opportunity to turn a pen recently using blanks from mckenziedrums. Tim does something a little unique with his blanks where he uses real diamond dust for the shimmer in the blanks rather than a typical pearl powders.
The blanks come mostly square and in typical 5" pen blank size. The largest diameter I was able to achieve once completely rounded was 18mm so it should be more than enough room for any pen you want to use it on.
Since it's Alumilite it lends itself to either kit or custom pens and is easy to turn and polish. The color saturation and penetration is good with no dead areas that I found. Definitely no air bubbles either so they're good solid blanks.
As for the diamond dust, it's a nice touch but I wouldn't say that the shine factor is quite as high as some of the powders available but as Tim said, it's more about being able to tell your customer that it's real diamond dust and I believe he said he was working on certificates to include that explain this.
My only real criticism, and mind you I have a limited sampling of 2 blanks, is that the saturation of the dust doesn't get all the way to the bottom of the mold, or it floats up. Either way it leaves one side of the blank not quite as shiny as the other. However the thinner the pen body the less that will be noticeable. The pen in this picture is around 15.5mm in diameter on the cap and 14.5mm on the body.
Overall I think they are very nice blanks and provide a bit of variety and new blood to what is available to the pen market.
Nice job Tim.
Nice job Tim.
