International Association of Penturners (http://www.penturners.org/forum/)
-   Fountain Pens (http://www.penturners.org/forum/f50/)
-   -   Parker Duofold section to body threads? (http://www.penturners.org/forum/f50/parker-duofold-section-body-threads-151346/)
stuckinohio 11-06-2017 09:48 PM
Does anyone know what threads are used on the section to body of a Parker Duofold Centennial?
duncsuss 11-07-2017 09:54 AM
Sorry, I don't -- but I have a Duofold (Centennial? International? Not sure what the exact name of this model is).
I doubt that I'd be able to read the pitch with sufficient accuracy to create a barrel that the section would fit, but I'll take a look. Might be a day or two before I get to it.
Meantime -- you could check out www.FountainPenNetwork.com to see if the question has already been asked & answered there.
stuckinohio 11-07-2017 01:11 PM
That would be awesome! I have searched fountain pen network to no avail. I have someone that will supply me with the section, but I don't have it so I can't measure the pitch unfortunately.
No rush of course. Thank you.
stuckinohio 11-09-2017 09:01 AM
Well, I became a member of the fountain pen network and found that the thread pitch is most likely .75 and the thread is either 8.5 or 9, so that is easy and cheap to try at least. I might even have both dies.
duncsuss 11-09-2017 09:41 AM
Glad you posted, I'd forgotten. Here's what I find when I measure mine:
The diameter of the un-threaded portion behind the threads (which looks the same as the major diameter of the threads) is 8.72mm (0.343", 11/32")
The diameter of portion which slips through the barrel threads (which looks the same as the minor diameter of the threads) is 8.06mm (0.317", 41/128").
Attempting to line up the peaks of my M9 x 0.75 tap with the valleys in the section, it looks like 0.75 is a very close match. My eyes (even with a x10 visor on) aren't good enough for me to say if it's an exact match.
If this really is a metric tap. I'd be inclined to guess at M 8.75 x 0.75.
HTH
stuckinohio 11-09-2017 11:34 PM
Well then, I will get the 8.75 x .75 and the 8.5 x .75 if I don't already have it and try both!
Thank you for your time. I appreciate it.
eharri446 11-10-2017 07:56 AM
I found out the other day that you can buy ready made Bock #5 and #6 sections and they have a M8.5X1 thread.
stuckinohio 11-10-2017 08:37 AM
Where can you get those?
bmachin 11-10-2017 08:46 AM
Lewis,
See here:
Sections for custom fountain pens and kitlss pens
Bill
stuckinohio 11-10-2017 09:01 AM
Thank you Bill.
It's an interesting option, particularly since the bock #5 housing is so picky. I expected them to be Ebonite though! But, the plating options are very nice.
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
