Heritance nib question
IPD_Mr
Zionsville, In
We have had one in an El Grande for years with no problem. The wings on a Heritance cannot be as wide as a standard non-flex nib. The curve of the nib helps to stiffen the nib and too much of a curve would counter effect the flex. Just make sure you have a tight fit.
alamocdc
San Antonio, Texas, USA.
Thanks, Mike! It appears to fit tightly. I can't dislodge it any easier than I did the stock nib. But I just noticed that the section is split! And I know I didn't use enough pressure to cause that. AARGH! And the customer was all set to pick it up today!
