Changing nib on a Chruchill
armyturner
Oil Trough, AR, USA.
I looked at Anthony's tutorial on replacing nibs, in which he states that there were some issues with the El Grande. Has anyone here replaced the nib on a Churchill with one of the 18k Heritage nibs? If so, did you have any issues. I just received an order for one over the weekend and have never removed and replaced the nib on one before.
ashaw
Phila, PA, USA.
I replaced my churchills nib with the 18k gold nibs. No problems at all once you know what your are doing[B)]. Just pull the feed and nib out you may have to wiggle it a little. But everything fits just fine.
ed4copies
Local Chapter Manager
Racine, WI, USA.
Alan,
You're a nice guy, but that is REALLY UNDERSTATEMENT at it's finest!!!
The 2 I removed required a VERY strong pull, after 5 minutes of twisting, turning and questioning whether I was doing something wrong!!!
Oh, then it POPPED RIGHT OUT!!!:D:D
DCBluesman
Passed Away Mar 3, 2016
WOODBRIDGE, VIRGINIA
If you rinse the whole section with warm, clear water, then hold the nib and feed together between your thumb and forefinger, both pieces will wiggle free of the holder. Some components require a bit stronger wiggling.
bgray
Milan, OH
I've never had any problems removing El Grande/Churchill nibs.
Sometimes cover it with a paper towel for a better grip.
ashaw
Phila, PA, USA.
One note do not bend any of the wings(?) of the feed. In otherwords do not put your fingernail in between the wings[B)]. The feed will never work correctly again.
Texatdurango
Show Low, Arizona
Originally posted by ed4copies
....The 2 I removed required a VERY strong pull, after 5 minutes of twisting, turning and questioning whether I was doing something wrong!!!
Perhaps a bowl of Wheaties might be in order prior to attempting this task!:D
mdburn_em
Chesapeake, VA, USA
From outa left field somwhere...
Don't you think Ed might need something stronger...like Geritol?
Sorry Ed, couldn't resist...it's only cuz you've been ignoring my request for your kitty-logue.
ed4copies
Racine, WI, USA.
CATalog sent,
no kittylitter enclosed,
hope my cougar poops on your e-mail!!!
GERITOL!!!?????!!!![:0][:0][:0][:0]
Nasty kid!!!:(:(:(
