Baron Fountain Pen nib - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Fountain Pens
  Forgot Password
Fountain Pens The unique aspects of making, using, and selling fountain pens.
Welcome to penturners.org!
Reply
Old 01-04-2017, 10:08 AM   #1 (permalink)
scotian12's Avatar
Photos: 0
Default Baron Fountain Pen nib
Can the Baron nib be replaced by twisting/rocking it out of the section or is it permanent? I would like to replace the nib with a wider nib....any suggestions on brand of nib? Thanks Darrell Eisner
__________________
Darrell Eisner
www.scotianpens.com
Canada’s Largest Online Store of Wooden and Acrylic Pens
scotian12 is offline   Reply With Quote Top
Old 01-04-2017, 10:29 AM   #2 (permalink)
KenV's Avatar
Photos: 0
Default
Darrell, have not done one recently, but have stuck Heritance nib into barons in the past. Do not remember any thing unusual in the process.
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 01-04-2017, 10:49 AM   #3 (permalink)
scotian12's Avatar
Photos: 0
Default
Thank you Ken. Does anyone else have any experience in replacing these nibs from the section....they seemed to be permanent making me replace the whole section. Darrell
__________________
Darrell Eisner
www.scotianpens.com
Advertisement
Old 01-04-2017, 12:32 PM   #4 (permalink)
Photos: 13
Default
The baron has a press fit nib and feed inside of a threaded housing like most/all other kit pens.
AWLogue is offline   Reply With Quote Top
Old 01-04-2017, 02:15 PM   #5 (permalink)
Local Chapter Manager
ed4copies's Avatar
Photos: 27
Default
Hi Darrell, yes, it pulls out--not easy, but possible.
__________________
Ed Brown
ed4copies is offline   Reply With Quote Top
Old 01-04-2017, 07:05 PM   #6 (permalink)
scotian12's Avatar
Photos: 0
Default
Thank you all for your replies. I can get the gold and chrome kit nibs to pull out. However, the black Baron kit defies brute strength. However, with some interchange between the kits I can accomplishes my goal of changing the nib. Thanks for your sage advice. Darrell
__________________
Darrell Eisner
www.scotianpens.com
Old 01-04-2017, 08:07 PM   #7 (permalink)
keithncsu's Avatar
Photos: 7
Default
Sorry to hijack your thread, but I have a similar question! Is it standard knowledge/safe to assume that the fountain pen kits are all like this? Or is it a veteran knowledge, learn as you go, don't ask me how I know this type situation. For instance, I made one of the American Patriot kits and wanted to play around with other nib styles. Can I just swap them out and play around?
keithncsu is offline   Reply With Quote Top
Old 01-04-2017, 09:40 PM   #8 (permalink)
Mr Vic's Avatar
Photos: 2
Default
When you say a wider nib you are referring to tip size? I think the Baron is one of the few that still has a #5 nib instead of the now more common #6. You can also soak in some luke warm water to help loosen it up. A piece of rubber such as a jar opener assist will also help.
__________________
Mr Vic
Keep the shiny side up and the greasy side down.......
President Pikes Peak Woodturners - AAW Chapter
Mr Vic is offline   Reply With Quote Top
Old 01-04-2017, 09:48 PM   #9 (permalink)
ed4copies's Avatar
Photos: 27
Default
Quote:
If you own the kit, you own the right to break it. How else will you learn??
I broke dozens of kits, components, etc. It was no where near as costly as going to college (yes, I graduated) and I learned a lot more useful "stuff".
IF you try to take the pen apart and you don't succeed, you are unlikely to break anything in the nib section, as long as you don't use tools (pliers!!!)
__________________
Ed Brown
Old 01-04-2017, 10:10 PM   #10 (permalink)
Photos: 0
Default
Mr Vic is right. Heat is be your friend. Warm water, warm air--no heat guns, no hair dryers on high. Heat a little, wiggle and twist a little, repeat with a little more force until things loosen up.
Bill
bmachin is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
