Wooden thumbdrive (USB Flash). HOW-TO
See more from Alejanders
Alejanders
Moscow, Russia
As I promissed, share my guide.
Original article in LiveJournal (In Russian, if you want just view pictures):
http://alejanders.livejournal.com/11593.html
Not sure, that my translation will me much better, then Google translation. :)
If explaination needed - tell me please.
http://translate.google.com/transla...=http://alejanders.livejournal.com/11593.html
There is nothing special in technics or design.
I have made that thumbdrive special for guide, so chose simple and easy design, but interesting wood.
Start:
attachment.php
In progress:
attachment.php
And result:
attachment.php
Perhaps someone could clarify for me. The Pins shown in the case appear to be like knife pins or rivits holding things together are those drilled through the electronics? What holds the flash drive to the Brass? Do you glue/epoxy the brass to the wood?
Thanks.
Thanks.
I think that is for the indicator light. That light that flashes when the drive is transfering data.
You are right. One holle/river is a LED.
Its position depends from position of LED on circut board. Hole not trough electronics, it jut to LED.
On my earlier thumbdrives I drilled hole. Later - insert tube.
Second hole is for lanyard. It is just 1-1.5 mm (1/25") far from board edge.
Actually I make lanyard hole as design element. Thumbdrive looks much better with it. You may place lanyard hole on cap.
That's my first thumbdrive. No lanyard hole.
s640x480
Second. With lanyard hole.
00011yr4
Double LED (double hole)/
s640x480
Blue LED.
s640x480
Backside LED in tube.
s640x480
