Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Other Things We Make
Other Things We Make Show off your bowls, stoppers, flatwork, etc.
Reply
Old 06-25-2011, 11:49 PM   #1 (permalink)
Photos: 0
Default wine stopper assembly question
I just started to make wine stoppers and did't feel that the threaded connection between the acrylic top and the SS stopper was a good strong fit, so I decided to add a little CA inside the acrylic hole (which I used a tapping tool on and was on a threaded chuck).
After I screwed the two together and a few minutes went by, I started to get some CA leaking out onto the acrylic and SS stopper making a mess and ruining the stopper. I'm guessing that there was just enough air pressure in there, combined with maybe to much CA, and possibly not enough space left.
Does anyone have any suggestions to avoid this in the future? I'm concerned that just screwing it together may not be strong enough and may come loose and/or strip away the threads. Not a good thing if you are trying to sell them and this happens to a customer.
Mike
mdwilliams999 is offline   Reply With Quote Top
Old 06-26-2011, 02:26 AM   #2 (permalink)
Photos: 0
Default
If you're using a 5/16" drill bit to drill the hole you shouldn't have a problem. The bit that came with my kit was the wrong size.
__________________
It's not what you take when you leave this world behind you, it's what you leave behind you when you go.
ohiococonut is offline   Reply With Quote Top
Old 06-26-2011, 06:19 AM   #3 (permalink)
Photos: 0
Default
I use a small amount of epxoy to keep mine together. I have more problems with folks unscrewing them thinking they are a pen and looking for the ink fill.
__________________
Rick Beckham
Belton, TX
beck3906 is online now   Reply With Quote Top
Old 06-26-2011, 07:52 AM   #4 (permalink)
monophoto's Avatar
Photos: 0
Default
Your analysis of the problem is probably correct. But I would add one other factor - - -
I think you used too much glue. You don't need to glue the components together - instead, all you want to do is lock the threads. Put a drop (ONLY) of thick CA or epoxy on the threads inside the turned top so that screwing the stud into the hole spreads the glue on the threads. Don't try to fill the hole with glue. Polyurethane glue will work, but its tendency to foam and expand increases the risk of getting excess glue coming out of the joint.
Second, a trick that helps manage this problem is to undercut the top of the stopper a bit. I use a 3/4" forstner bit to cut a recess about 1/16" deep in the bottom of the blank before drilling the 5/16" hole that then is threaded at 3/8" x 16tpi. Later, when the finished stopper is assembled, the metal base fits into that recess. That means that the turning extends slightly and covers the joint between the turning and the metal base. If any glue squeezes out, it will be hidden in the recess.
__________________
monophoto is offline   Reply With Quote Top
Old 06-26-2011, 10:11 AM   #5 (permalink)
nava1uni's Avatar
Photos: 18
Default
I do this but I also only put a little CA or epoxy only on the end of the stopper and then screw the two pieces together. The glue is spread along the threads with only a tiny, if any excess, and it is hidden. If you use epoxy and there is any squeeze out you can clean it up with a cloth wet with 70% alcohol and it will be just fine.
__________________
Cindy
San Francisco, CA
"All the strength you need to achieve anything is within you"
nava1uni is offline   Reply With Quote Top
Old 06-26-2011, 05:54 PM   #6 (permalink)
ssajn's Avatar
Photos: 0
Default
Try using Loctite. If you use too much you can wipe off the excess.
__________________
Dave
http://woodjunky.weebly.com/
My money talks to me, it says good bye.
A penny saved is a government oversight.
ssajn is offline   Reply With Quote Top
Reply
Bookmarks
Tags
ca , glue , wine stopper
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2012 by Penturners.org, LLC; All Rights Reserved
