Wands - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Other Things We Make
  Forgot Password
Other Things We Make Show off your bowls, stoppers, flatwork, etc.
Welcome to penturners.org!
Reply
Old 07-26-2018, 07:37 PM   #1 (permalink)
sbwertz's Avatar
Photos: 41
Default Wands
I've been making Harry Potter type wands. My grandsons both want one, and a couple of people locally ordered one, and several of my blind turners want to make one.
Anyone make one? Any tips? I've made one of mahogany. Turned out pretty good. They were thrilled with it anyway.
I'd like to try some decorative stuff. I have an index attachment I got a while ago and have never used.
__________________
Sharon in Phoenix
sbwertz is offline   Reply With Quote Top
Old 07-26-2018, 09:20 PM   #2 (permalink)
MRDucks2's Avatar
Photos: 0
Default
Only thing I know is elderberry is supposed to be the most powerful. (Harry Potter weekend at my house)
__________________
Think deeply, Speak gently
Love much, Laugh alot
Work hard, Give freely
Be kind &
Leave The Rest to God
MRDucks2 is offline   Reply With Quote Top
Old 07-27-2018, 07:42 PM   #3 (permalink)
Photos: 0
Default
A turner on another forum suggested making a morse taper for the headstock - works very well.
donstephan is offline   Reply With Quote Top
Advertisement
Old 07-27-2018, 07:53 PM   #4 (permalink)
Sylvanite's Avatar
Photos: 35
Default
When I made Wands, I turned the handles separately and glued the parts with a mortise/tenon joint. I used a jam-chuck and collet chuck to turn the sections between centers.
I hope that helps,
Eric
Sylvanite is offline   Reply With Quote Top
Old 07-31-2018, 08:20 PM   #5 (permalink)
Sylvanite's Avatar
Photos: 35
Default
Or you could go one step further, and make a wand pen.
Regards,
Eric
Old 07-31-2018, 09:41 PM   #6 (permalink)
Photos: 0
Default
I also made 2 part wands with a tenon joint. They were for our granddaughter, doing it in 2 parts let her turn the handle and I made as she called it the "magic" part. We used various types of wood so they looked laminated.
dogcatcher is offline   Reply With Quote Top
Old 08-02-2018, 08:21 AM   #7 (permalink)
Photos: 21
Default
My wife has been on me to turn some wands for a while now. She thinks with our sparkly resin they'd be a big hit... Are you all using a collet chuck to hold the spindle? If I use my current molds they'd start out round at least so that will save me some grief but I can't see how this would be good to turn between centers... Two pieces would be easier but I'm thinking the collet is the way to go.
McKenzie Penworks is offline   Reply With Quote Top
Old 08-02-2018, 09:23 AM   #8 (permalink)
Photos: 0
Default
Quote:
I use my collet. For the handle end, I drill my blanks with a 5/16" bit about 1" deep. I made a 5/16" spur drive out of a steel rod that I mount in my collet. On the end of the steel rod I cut an X and then filed to points like a spur drive. I tap this end into the hole in the blank then turn between centers.
For the "magic" part, I turn them between centers, first turning the 5/16 tenon to fit the hole in the handle. Then get as fancy as I want as I turn the "magic" part. The tenon should be close, but does not have to be perfect tp glue it in the handle. To clean up the live center end, I stick the tenon in the collet chuck and sand it smooth starting with 80 grit.
The secret is to make these in batches of 12 or more, it is a time killer changing out tooling. I cut and drilll the handle blanks, then tirn all of the handles. Then cut and turn and sand the "magic" part and tenons, then sand all of the tip.
Sizes, about 3.5 to 4 inches for the handle, about 6 to 7 for the "magic" part. Sometimes I cheat and use dowels for the "magic" part, all they need is sanding and rounding the end. I made a 144 once, the dowels saved my sanity. My advice is be CREATIVE, make them all a little different, DO NOT try to make them all the same.
Old 08-02-2018, 10:18 AM   #9 (permalink)
Photos: 21
Default
Makes sense and thanks for the guidance and tips! I've got a number of pin chucks that would get the job done too for holding them on I suspect. If not, it's a good excuse to bug Rick and get a few more. Just realized I have bin full of stablized and dyed wood from a project that never panned out and I think a lot of it would work for handles. I need a creative outlet between pouring blanks and I think this will be fun.
Old 08-02-2018, 11:41 AM   #10 (permalink)
Photos: 0
Default
You don't need a pin chuck. A piece of steel rod 5/16" in diameter about 5" long. On one end, first drill a 3/16" hole about 1/4" deep. This is easily done using your collet chuck. Next use a hacksaw to cut an X about 1/4" deep. Then take a rattail file and file 4 "teeth" on the end. Your drive spur for the collet chuck is finished. To use, stick in the hole of the handle blank and tap it with a mallet. Then mount the mandrel and blank in your collet chuck.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
