Charlie_W
...No, not Rick Flair .....Turning with Flare is where we are going today!
This is a bowl which I turned a couple months ago from some fresh green cherry.
I started out just roughing it out to be finish turned later but was having too much fun so I just kept going and ended up with a green to finish bowl in one turning. As you can see, the rim has really moved as it dried.
It is just under 12" diameter and 7" tall. The flared rim is 3/32" thick and increases to 3/16" down the side where it curves into the bottom. I left the bottom a little thick just for some weight.
Finish: Originally sanded with walnut oil but re-sanded after a couple weeks and had a couple of coats of some Danish Oil Finish.
I kept it in a paper bag for about a month while it was moving just to slow down the drying....so far, no cracks!
Enjoy!
Enjoy!
