Three More
See more from W.Y.
W.Y.
BC, Canada
Those are going to be some mighty big pens. :biggrin:
Curt
Do we show pens on the "Other Things We Make" board too ? :biggrin: I have only made three hundred and fifty pens and now I have made more bowls than that . Didn't have to buy any kits for the bowls either . :)
magpens
Canada
How could you possibly have done that .... your shop looks too neat and tidy !
W.Y.
BC, Canada
My shop is 10 x 10 outside and a little over 90 square feet on the inside. Everything you see that I make is done in that micro shop.
It is so small that I sometimes have to step outside just to change my mind :biggrin:
jeff
Administrator
Staff member
Westlake, OH, USA.
William, remind me... do you turn those after glue-up?
I really enjoy looking at your work! It's even more impressive knowing that you produce those in a 90sq ft. shop. That should be an inspiration to anyone who doesn't think they have enough space for a workshop.
W.Y.
BC, Canada
I still wanna know where you get trees that grow like that?
Did anyone tell you how many comedians are out of work? Better keep your day job. :).
Don't mind me . . . I am also guilty of joking around quite a bit . Unfortunately some read me wrong for it but that's their problem . :laugh:
W.Y.
BC, Canada
The rings are cut from the board on a very accurate angle in thousands of an inch to form the bowl . The walls are too thin to safely use turning gouges etc. on them but I have got it down to about just ten minutes of sanding per bowl on the lathe . I even have a video to prove it .
Here is the second video I made of that micro shop I built a couple years ago.
https://www.youtube.com/watch?v=vYbaOpsR2Rw
CREID
Vancouver, wa
Curt
I was just informed by a private message that I offended you. My post was meant as a jest, not a criticism in any way. You do beautiful work. It is sad that no jest goes without punishment here.
Curt
W.Y.
BC, Canada
Curt
Curt
OMG ! there are some sick minds out there that have no sense of humor and always have to take things negatively . You did not offend me in the slightest and I enjoyed our little exchange of kidding around with you. Don't let jerks like that bother you . They are not worth the time of day .
