Tear out on turned bowl - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Other Things We Make
  Forgot Password
Other Things We Make Show off your bowls, stoppers, flatwork, etc.
Welcome to penturners.org!
Reply
Old 02-28-2015, 11:59 PM   #1 (permalink)
Photos: 0
Default Tear out on turned bowl
What can I do to fix the tear out on a bowl. I don't want to sand it to get rid of it because it will make my side too thin. I am looking for a fix that would still be food safe.
joe966 is offline   Reply With Quote Top
Old 03-01-2015, 12:16 AM   #2 (permalink)
The Penguin's Avatar
Photos: 0
Default
you either have to sand it out - or turn it out.
The Penguin is offline   Reply With Quote Top
Old 03-01-2015, 12:35 AM   #3 (permalink)
flyitfast's Avatar
Photos: 9
Default
If it fairly deep, fill it with colored epoxy...and they turn and sand it smooth. Give a feature!!!!!!
gordon
__________________
SOMETIMES I PRETEND TO BE NORMAL... but it gets boring.....so I go back be being me.
The word 'listen' contains the same letters as the word 'silent. Is that like <<<<<ZIP IT<<<<<<
flyitfast is offline   Reply With Quote Top
Advertisement
Old 03-01-2015, 08:19 AM   #4 (permalink)
MarkD's Avatar
Photos: 56
Default
I have found this method to help alot with end grain tearout near the end of the bowl turning process. Turn your bowl close to the finished size using very sharp tools then give the bowl a very light coat of shellac ( I use Zinsser Bullseye shellac in a rattle can from Lowes ). Sharpen your tools again and then use a sheer cuts to finish the bowl.
Bulls Eye ShellacThings I have found that helps with end grain tear out is very
__________________
Mark
MarkD is offline   Reply With Quote Top
Old 03-02-2015, 01:34 PM   #5 (permalink)
triw51's Avatar
Photos: 0
Default
I might suggest sanding (about 220 grit) until you have about a teaspoon of dust and then add thin CA glue and with lathe at SLOW speed spread the slurrry over the tear out area then wet sand with the CA. Let cure for about an hour then sand and finish.
Two cautions wear gloves and have good ventalitation
__________________
ZIP IT Please
Western Creations Forge and Woodworking
Isaiah 58:6
triw51 is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
bowls , turning
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
