heritagebob
I am just getting into making stoppers,, I recently purchased a kit from Woodcraft that had 4 stoppers, a drill bit and mandrel,, was told all are compatable and should be good to go...... well wll is well EXCEPT.. after I drill my hole and thread on the mandrel, turn to shape, remove from mandrel I fin the threaded stopper to be a bit "sloppy" and have to put some epoxy inside and let it dry,,, how can I be assured that the stoppers I guy will fit the hole I have drilled...
Also have learned thru "R&D" that a hex head bolt mounted in a drill chuck on the lathe makes a good mandrel
Where can I find good stopper that will thread nicely into the 3/8 hole I drill ,, I am not a machinest so charts arnt much help to me
Rookie at work
Rookie at work
