Solid wood coasters
See more from mmayo
mmayo
Tehachapi, CA
In addition to well over 200 pens I display a variety of other items people can buy. I have been asked for wood coasters and there will be many sets for sale soon. The addition of a small jointer has reduced any gaps to zero and throughput is much faster for cutting boards and items like these coasters. They are 4" square and around 3/8" thick. I make them with 4/4 stock and use the resaw king to resaw them in half.
Though not visible, they are very smooth, water resistant and have lots of shine. I used several coats of wipe-on poly, sanded to 1200 grit and buffed with all three buffs in a Beale Buffing System. The polyurethane and carnuba wax should help any liquid bead up nicely.
mmayo
Tehachapi, CA
Coasters are a great idea and they look great. I bet you have cutting boards to match!
Yes
Truth be told
I made three 8" boards too long and had 4"+ of excess. The light went on and I'm going full speed now. A friend says that the best woodworker hides his mistakes elegantly. I try
mmayo
Tehachapi, CA
More coasters
Two hours of work this afternoon - 43 coasters. Cherry, oak, poplar, bloodwood, Padauk, walnut, maple and purpleheart. Cut 4/4 stock to 4" x 8"+ kerf, resawed, drum sanded, cut square and routed with a 1/8 round over but. Less cut offs in the shop and salvaged something to sell.
Good luck if this looks like something to sell when they have a pen.
Curly
Saskatoon SK., Canada.
They look good and great way to use up odds and ends although it is a lot faster to work with long stock. Given any thought to turning round ones on your lathe?
mmayo
Tehachapi, CA
Here are solid hardwood coasters
After finishing they look and feel right.
Puerto rico
