Shaving brushes
See more from vferdman
vferdman
Western Massachusetts
I have completed the custom brush in Black Peacock resin. It received a knot provided by the customer. The brush came out amazingly well. I hope the new owner is happy with it for years to come.
Dimensions (approximate):
Total height: 106mm
Handle height: 58mm
Loft height: 48mm
Knot: 28mm (fan shape)
vferdman
I have created a brush handle for a fellow brush maker as part of a trade. I'll be getting some custom resin blanks in return. This handle is also made of Black Peacock resin, but there is very little blue in this one. These resins chunks can be deceptive as to what's inside them. This one showed a lot of blue, but most of it got turned away. There is more blue deeper inside, but it's a subtle effect. Anyway, the handle came out great and I hope the new owner is happy with it.
Handle height: 58mm
Knot opening: 25mm
vferdman
I also created a new brush for my Etsy shop. This one has a combination I discovered recently that I really liked. Marble Pearl and Red Wine center ring. I really love the way the stark marble is popped by the juicy red. Knot is TGN two band finest. This batch of TGN knots I got is really good and reminiscent of the good old days of TGN goodness.
Brush Dimensions (approximate):
Total height: 102mm
Handle: 54mm
Loft: 48mm
Knot: 26mm Bulb shape
vferdman
I have created a boar brush for my Etsy store. This knot came from TGN, but is an Italian knot used in Omega brushes. It came with the black plastic ring, just like Omegas. I removed the ring because I do not like the way it looks and also I like to set the loft a tiny bit lower than set with the ring. Resin is imported (German, I think) in Leopard skin print. Really nice material and seems sturdier than regular polyester resin.
Total height: 122mm
Handle: 62mm
Loft: 60mm
Knot: 28mm
Dale Lynch
Hastings,NE
Nice brushes.What do you mean by good ol days?It's been a while since I've made a brush,has there been a change in the grading or quality?
thrustmonkey
Illinois
I tried making a brush and razor set from PSI about 8 months ago. The razor is fine but the brush started falling apart. The CA glue failed on the knot, then the chrome cup that the knot was glued into came loose from the handle. I re-glued them with epoxy and it seems to be holding up for now.
I'd like to make some more but I'm a little leery about it.
One question I do have is how do you get that weird smell out of the knot?
Ross
Waggoner
Houston,TX
Total height: 102mm
Handle: 54mm
Loft: 48mm
Where would one be able to get a blank like this?
vferdman
Okay, to answer some questions.
1. The funky badger smell will come out of the knot after a few uses.
2. I buy these blanks at Woodturningz.com They have a wide selection of wood, resin and other materials. Also good pen supply house.
3. Do not buy kits for making shaving brushes. Just get knots and blanks and turn them yourself. Use epoxy to set the knot, not CA.
Hope that helps.
vferdman
I have created a brush by custom order from a new to me resin called Blue Pearl. This stuff looks like moonstone if you have every seen it. It's mostly the color of moon and under a certain angle the swirls of bluish pearly color appear. It's quite stunning. I used a piece of Black Peacock for a ring in the middle for an accent.
vferdman
I also have created a new brush for my Etsy store, LoveYourshave. This one is made with the same materials as the custom one in the previous post, but with a slightly smaller knot and a slightly different shape. It came out beautifully.
Total height: 110mm
Handle: 61mm
Loft: 49mm
vferdman
Another new brush for my ETSY store. This one is made with Moonstone and Black Olive resins. Very beautiful combination. I will be using Moonstone resin a lot more. I really love it. Knot is TGN two band finest.
Total height: 108mm
Handle: 59mm
Loft: 49mm
vferdman
I have created a new brush for my ETSY shop.
This one is made with a Golden Marble and Copper resins. Copper is used for a ring in the middle of the handle and is really a good accent on the Golden Marble, which is just like the regular grey marble, but gold flakes in it. It is warmer in tone than the grey marble and is a treat to the eyes. The knot is TGN two band finest.
Total height: 107mm
Handle: 58mm
Loft: 49mm
vferdman
I have created a brush by custom order. This one has Bloodwood on the bottom, Katalox wood at the top, is CA finished and polished to a glass-like shine. The knot is TGN two band finest. It's a barber-style brush with a longer handle. Came out great.
Dimensions:
Total height: 133mm
Handle height: 83mm
Loft height: 50mm
Knot diameter: 28mm bulb shape
vferdman
A new brush for my Etsy store. This one is made with Gold Marble and Copper resins. The knot is TGN Two Band Finest.
Total height: 105mm
Handle: 58mm
Loft: 47mm
vferdman
I have created two brushes for a custom order.
First one in Bengal Tiger resin.
Dimensions:
Total height: 102mm
Handle height: 54mm
Loft height: 48mm
Knot: 28mm hybrid shape
The second brush is in Faux Ivory resin.
Dimensions:
Total height: 113mm
Handle height: 60mm
Loft height: 53mm
Knot: 31mm bulb shape
vferdman
I have created a small travel brush from natural horn and two band finest badger hair. This brush is inspired by Simpson Wee Scot. It is slightly larger than Wee Scot and sports a larger two band finest knot, but the idea of a thumb sized brush that really works amazingly well is inspired by Simpson's iconic brush.
Total height: 73mm
Handle: 35mm
Loft: 38mm
Knot: 18mm Bulb shape
vferdman
I have created a brush by custom order. Handle material is Bloodwood with a Cyanoacrylate finish. Knot is customer provided two band badger.
Brush dimensions:
Total height: 110mm
Handle height: 60mm
Loft: 50mm
Knot: 32mm Bulb shape
vferdman
I have created another travel brush. The handle is natural horn, the knot is TGN two band finest. I really enjoy small brushes and Simpson Wee Scot was definitely the inspiration for this one. This brush is slightly larger than the Wee Scot and is just an amazing performer according to the test lathers.
Total height: 75mm
Handle: 34mm
Loft: 41mm
vferdman
I've created two brushes for custom orders.
First one is made with Black Olive resin and TGN two band finest badger knot.
Second one is made with Black Peacock resin and Peacock resin center ring. Knot is two band badger from TGN.
vferdman
I have created three new brushes for my Etsy shop.
First one is made with "Black Peacock" resin for the main body and "Peacock" resin for center ring. Knot is two band finest badger.
Second brush is made with "Purple and Gold" resin. Knot is two band finest.
The third brush is made with "Golden Marble" at the top and "Molten Metal" resins at the bottom.
vferdman
I made a new brush. This one features Blue Pearl resin main body and Peacock ring. Knot is two band finest. The handle shape is an experiment and the price reflects it.
Total height: 105mm
Handle: 58mm
Loft: 47mm
vferdman
I have been busy creating new brushes in my shop. Here they are.
First one is by custom order. Black Peacock body with Peacock ring. Two band finest badger knot in fan shape.
Dimensions:
Total height: 111mm
Handle height: 64mm
Loft height: 47mm
Knot diameter: 25.5mm
vferdman
A new brush in my Etsy store. This one is made with Golden marble (main body) and Copper Pearl (ring). Two band finest badger knot.
Total height: 107mm
Handle: 61mm
Loft: 46mm
