Shaving brushes - Page 29 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Other Things We Make
  Forgot Password
Other Things We Make Show off your bowls, stoppers, flatwork, etc.
Welcome to penturners.org!
Reply
Old 08-08-2017, 02:16 PM   #281 (permalink)
Photos: 1
Default
Just finished a brush by custom order. Tie-Die resin with Elite High Mountain White two band badger fan knot.
Dimensions:
Total height: 120mm
Handle: 70mm
Loft: 50mm
Knot: 30mm
__________________
My handmade and restored shaving brushes on Etsy
Wherever you go - there you are.
vferdman is offline   Reply With Quote Top
Old 10-12-2017, 11:32 AM   #282 (permalink)
Photos: 1
Default
I added two new brushes to my Etsy shop today. Please check them out.
First one is a Keyhole in Blue and Gold resin with a two band finest knot.
The second one is available as a "Handle Only" or with a choice of four knots. BOSS synthetic, Tuxedo synthetic, TGN two bad finest fan or Elite Manchurian White bulb.
__________________
Old 10-13-2017, 02:41 PM   #283 (permalink)
Photos: 1
Default
Another new brush in my Etsy store. This one is Maple wood and Tie-Die resin with choice of knots: BOSS, Tuxedo, TGN finest fan or Elite Manchurian bulb.
__________________
Advertisement
Old 11-10-2017, 10:50 AM   #284 (permalink)
Photos: 1
Default
I have created two similar, but different brushes. I was kind of taken with the beauty of the combinations produced, so I went with some experimental techniques.
Here is the first one. Black Olive resin on top, Renaissance on the bottom and Crushed Cranberry (red wine) for a ring accent. I have cut the bottom part in two and flipped the parts end for end to obtain a sort-of a Yin-Yang effect. I thought it worked well in this case. I inserted a thin black line to delineate the transition between the halves. This piece is offered with a choice of knots: BOSS, Tuxedo, TGN two band or Elite Manchurian.
__________________
Old 11-10-2017, 10:55 AM   #285 (permalink)
Photos: 1
Default
Second brush is more traditional with no vertical splits. Resins are: Golden Black on top, Renaissance on the bottom and Crushed Cranberry (red wine) for the ring accent. This one is also offered in choice of knots or as "handle only".
__________________
Old 11-11-2017, 06:41 AM   #286 (permalink)
fernhills's Avatar
Photos: 2
Default
Nice brushes. I was just wondering how you glue your wood and resin brushes together. Do you just use epoxy ? Is there a special way of fasten them ? I saw that the golden nib was doing that quite some time ago. I have not tried one yet. I have tons of woods but short on resins. Nice work . carl
__________________
Carl, Hellertown,Pa
fernhills is offline   Reply With Quote Top
Old 11-13-2017, 09:11 AM   #287 (permalink)
Photos: 1
Default
Quote:
I use 30 minute epoxy to glue the pieces together. Wood to wood, wood to resin, it all works great. I make sure my cuts are square, otherwise you get wobble line at the junction.
Try it, you'll like it.
__________________
Old 11-13-2017, 10:15 AM   #288 (permalink)
fernhills's Avatar
Photos: 2
Default
Thanks alot, I use 5 min. epoxy on most things and have good results, i guess i was worried about the end to end joint on such a wide item and then exposed to water. I will try a few and see how it goes. Carl
__________________
Carl, Hellertown,Pa
Old 11-28-2017, 10:58 AM   #289 (permalink)
Photos: 1
Default
Two new brushes in my Etsy store. The two are identical. Made with shredded US currency resin in Chubby style. Choice of knots available. Please check it out!
__________________
Old 11-28-2017, 11:01 AM   #290 (permalink)
Photos: 1
Default
A brush by custom order. Muave Coral, Emerald Green and Royal Harvest resins. Tuxedo synthetic knot.
__________________
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
