SCROLLSAW MOBIUS RIBBONS
See more from Bob Collins
Bob Collins
Australia
View attachment 168026 Mobius Ribbon.jpg A Mobius Ribbon made from plywood and cut on the scrollsaw using a bowl from a board method and consists of 2 half and 10 quarter bowls.
6.jpg This is a Spiked Mobius Ribbon using the same method as above. A couple of projects i made before attempting to make pens. Cheers Bob C.
KenV
Juneau, Alaska.
Neat!!! Serious scroll saw work!!!
A caution though, if you decide to use plywood on the lathe be sure you have higher quality stuff with good glue lines and few if any voids. Construction plywood can come apart on the lathe.......
