Screw Thread ID - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Other Things We Make
  Forgot Password
Other Things We Make Show off your bowls, stoppers, flatwork, etc.
Welcome to penturners.org!
Reply
Old 11-30-2018, 01:25 PM   #11 (permalink)
Woodchipper's Avatar
Photos: 1
Default
OK, Ed. Duck tape might work instead of the oddball screw.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 11-30-2018, 07:16 PM   #12 (permalink)
More4dan's Avatar
Photos: 5
Default Screw Thread ID
Do you have a friend with a metal lathe, could make a tap. Iíve made several in the past on my little 7x10 lathe.
You could try mold release and set it with epoxy and unscrew it.
Here is a good place to go to calculate thread sizes and converting between metric and imperial sizes.
http://theoreticalmachinist.com/Thre...dImperial.aspx
Danny
More4dan is offline   Reply With Quote Top
Old 11-30-2018, 07:30 PM   #13 (permalink)
More4dan's Avatar
Photos: 5
Making your own specialty taps. Bock 5 mm
Link on making specialty taps.
Advertisement
Old 11-30-2018, 07:54 PM   #14 (permalink)
monophoto's Avatar
Photos: 0
Default
Quote:
Originally Posted by Ed McDonnell View Post
Berea was no help. I suspect they are just reselling a kit they buy in bulk somewhere and they didn't do the design.
I've never bought anything from Berea, and based on Ed's experience, I never will.
Problem 1: as consumers, we should be expect vendors to support the products they sell us, and if they won't/can't, then there are alternate products from other vendors.
Problem 2: using a non-standard thread is a really dumb design. The pizza cutter assembly clearly is manufactured, and cutting threads in the mounting stud is part of that manufacturing process, but I'm sure that it would have been less expensive to source standard threaded inserts, and then specify that a matching standard thread be machined into the cutter.
Problem 3: the best way to install threaded inserts is to screw a matching bolt (or a threaded shaft with a nut) into the insert, and then use a hex driver to drive the insert into the wood. Using a screwdriver, as suggested in the instructions for this kit, is a great way to bugger up the insert while still not driving it into the wood.
Problem 4: Berea Hardwoods like to sell wood, but they would sell more kits if they designed them to work easily with plastic materials as well as wood.
__________________
Louie
http://monophoto.deviantart.com
Instagram: @louie_powell_photo
monophoto is online now   Reply With Quote Top
Old 11-30-2018, 10:59 PM   #15 (permalink)
Photos: 43
Default
Hi Danny - I made a tap after reading your post back then. Never said thanks, so a belated thanks. It worked ok on wood and resin. Not so good on metal. I suspect I didn't get the heat treating right. I ended up getting it stuck in a piece of copper and made a pretty good mess of things trying to get it out. I'm going to try making a tap again some day, but not for this project.
I thought about using epoxy or alumilite to cast the threads, but the threads on this cutter frame are rough and I don't think the plastic threads would hold up to very many handle removals.
The threaded stud on the cutter frame has flats on two sides. Almost like it might be capable of self tapping. Maybe I'll try using one as a tap and see what happens. If I bung up the threads I can always just epoxy it permanently into the handle.
Ed
Ed McDonnell is online now   Reply With Quote Top
Old 11-30-2018, 11:07 PM   #16 (permalink)
Photos: 43
Default
Hi Louie - Overall, I've been satisfied with the products I've gotten from Berea. These pizza cutters are probably one of the least satisfactory Berea products I've dealt with. I only paid $6 for them and I think they are worth that (but not any more). I wouldn't be surprised to see Berea drop the kit or change over to a new kit from a different supplier.
Ed
Old 12-01-2018, 09:54 AM   #17 (permalink)
Photos: 1
Default
Quote:
Originally Posted by BRobbins629 View Post
Can you chase the male threads with a more comon die? Iíve done that before if youíre close.
This is what I do for some of the knives I buy. I've contacted the manf. about the scale screws without any results. Went to a hardware store, bought a drill bit, tap and die and now have custom threaded holes that I can thread a brass rod in. Saves me a bunch of time and a lot of headaches.
wolf creek knives is offline   Reply With Quote Top
Old 12-01-2018, 10:54 AM   #18 (permalink)
More4dan's Avatar
Photos: 5
Ed
Copper can be tough to thread even with a traditional tap. A former tap might be a better solution. Good luck finding those in a specialty thread though. It bends the material instead of cutting.
Why do you want to be able to remove the handle? I guess it would allow you to wash in the dish washer. JB weld and some other high temp epoxies are good to high temperatures (450 F) and would withstand the DW temps. With metal to metal you donít have to worry about using a clear epoxy.
Danny
Old 12-01-2018, 12:12 PM   #19 (permalink)
Photos: 43
Default
Hi Danny - My plan for the handle was to have a metal core that I engraved / carved and then encapsulated in clear resin. I'm concerned about how clear PR will hold up to a dishwasher over time. And I know for sure that aluminum / brass doesn't do well in a dishwasher.
After sleeping on it, my current plan of action is to bore out a snug fit recess for the threaded insert then epoxy it into the end of the metal rod. Not an optimal solution, but it will have to do.
Ed
Old 12-01-2018, 03:40 PM   #20 (permalink)
More4dan's Avatar
Photos: 5
Default
Ed
JB Weld might still be a better adhesive for the insert if it did make its way to the dishwasher without removal. Had a friend repair the head on his outboard motor with it. Lasted several years.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
