Question about razor heads from exoticblanks
See more from VotTak
VotTak
Staten Island, NY, USA
Hi,
Maybe someone have a knowledge about those razors... one is Match3 and another is Fusion. Question is are those heads interchangeable?
I know that kits from PSI have interchangeable heads but ecoticblanks have a bit different look.
Thanks ahead for your help.
ed4copies
Local Chapter Manager
Racine, WI, USA.
Your question is not clear to me, so here is my best explanation:
We sell both the MACH3 and the FUSION razor kits. Both of them are based on a threaded brass tube, into which the head is screwed. The threading on both heads is the same. So, if that is what you want to interchange, yes it can be done.
TO BE CLEAR!!! A MACH3 head will NOT take a fusion razor cartridge and, conversely the FUSION head will not take a MACH3 razor cartridge, so if that is your question the answer is no.
