A Plum Screwy Little Box.
See more from JD Combs Sr
JD Combs Sr
Owingsville, KY
Which translated means, "A threaded box made from Plum".
This is the finished version of the box that I showed having threads cut into it with my new threading jig.
Box is 4-1/8" in Diameter, 1-1/4" high(1.5" counting the grip), but it is very shallow at 5/8", but then it was just to test my threading jig.
Finish so far is one coat of satin WOP(will probably be the only coat).
C&C welcomed especially on the threading.
Charlie_W
Sterling, VA USA
Great looking little box JD! The threads are clean and crisp!..... Nicely done!
It looks to have almost true vertical sides....so.....does that make it a
"Plumb Plum Box"? :biggrin:
SDB777
Cabot, Arkansas USA
Plumb Plum Box....ya beat me!
Inquiring minds must know....how does moisture effecting the threading? Or the lid removal to be more accurate....
I like this small box!
Scott (it's sleeting here) B
JD Combs Sr
Owingsville, KY
Hi Scott, I am sure that a lot depends on the stability of the wood. I have the box in the shop and pretty much try the threads every day and have seen no change in how they fit. I am guessing that plum is a pretty stable wood. It was turned when the weather was frigid(dry) outside, today it is in the low 70s and humid but I can't tell any difference in the fit from day one. Hope this helps with your question, I will keep checking the fit through the summer.
