Padauk and Red Oak bowl
See more from Band Saw Box
Band Saw Box
Passed Away Dec 8, 2021
Hampton, VA 23666
Here is my latest bowl...Padauk and Red Oak. Evelyn gave me some bowl blanks for Christmas and a 2"x 6" piece of Padauk was one of them, I added a piece of 3/4" Red Oak to what would be the top. I sanded from 80 grit to 12000mm. The outside has 6 coats of Pen's Plus I still need to apply 4 more coats to the inside. I happy I didn't blow through the bottom of this bowl and pleased with how it came out. All C & C welcome.
JimB
West Henrietta, NY, USA.
Very nice job Dan.
One way to ensure you don't go through the bottom when hallowing is to measure the depth you want on the outside, mark that on a drill bit with tape, and then drill a hole in the blank on the lathe. Don't forget to take your recess into account when measuring.
RKB
Apollo, PA
Great bowl. I have started turning lidded boxes. I was encouraged by your posting of those early bowls made from basic wood pieces that were glued up into turning blocks. I did the same thing and have had alot of fun learning. I hope to move into turning better materials. Thanks for sharing.
Rod
