mecompco
Was gifted some antler, so decided to make this for the giftor. I think this particular piece of antler was old or something--the insides are very soft and porous. The centers sunk way in. It really should be a little thinner, but I was afraid it was going to come apart on the lathe if I took it down any more.
It took a LOT of CA to seal and I packed in as much epoxy as I could into the hole and ran the shaft about 2/3s into the handle. Added a steel washer to help hold everything together. I'm not extremely happy with the outcome, but it will be serviceable. BTW, it is a reed packer for basket making.
PS The shaft is 1/4" aluminum rod from Home Depot, shaped with belt grinder, file and sand paper. Bent in the bench vise.
