Warren White
I cogitated over this for a couple of weeks before I tried it. I watched several videos trying to get up the courage to jump in. Turning the 'shadow' corners was kind of scary to me.
Despite my trepidation, I am quite pleased with the result. The bowl is Rosewood which was given to me by my son for my birthday/Father's Day. It is 6" x 6" x 4"; and I admit it is not thin and elegant. I lack a couple of things to make such bowls; a tool to effectively refine the inside of the bowl, and a curved tool rest to minimize the chatter. Those will come in time.
After sanding to 400 grit; I used home brew friction polish (two or three coats); then several coats of Deft spray lacquer buffed with a towel in between coats and then buffed on the lathe.
Suggestions are most welcome. I really enjoyed turning this bowl in spite of the angst I felt before I even mounted it.
