My Chess Set - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Other Things We Make
  Forgot Password
Other Things We Make Show off your bowls, stoppers, flatwork, etc.
Welcome to penturners.org!
Reply
Old 07-16-2017, 08:42 PM   #11 (permalink)
Photos: 1
Default
Good start... looking forward to seeing the progress of the pieces...
__________________
Chuck
Tellico Plains, TN
https://www.etsy.com/shop/TellicoTurnings
If you look for trouble, it will find you!
TellicoTurning is offline   Reply With Quote Top
Old 07-16-2017, 10:05 PM   #12 (permalink)
Photos: 0
Default
That is beautiful work. I'm looking forward to seeing your progress.
Did you glue up the blanks at once and them cut them apart, or are you doing them one-by-one?
Cory
cbutzon is offline   Reply With Quote Top
Old 07-17-2017, 07:54 AM   #13 (permalink)
EBorraga's Avatar
Photos: 61
Default
Cory
Doing them 1by1
__________________
Regrets in death meant you've lived life wrong.
Check out my Facebook page at https://www.facebook.com/EBWoodworx/
EBorraga is offline   Reply With Quote Top
Advertisement
Old 07-17-2017, 12:00 PM   #14 (permalink)
EBorraga's Avatar
Photos: 61
Default
Here are the pictures facing the correct direction
20170716_154652.jpg   20170716_164112.jpg   20170716_155040.jpg   20170716_163224.jpg   20170716_164052.jpg
__________________
Old 07-17-2017, 08:59 PM   #15 (permalink)
Photos: 1
Default
Interesting jig you have there... I may have to "borrow" the idea on my next set of chess pieces... what did you use for the screw chuck?...
I used a pen chuck (home made) and just eye-balled the bases for size... mine may vary by a MM or so one way or the other...
I have several blocks of poplar and hickory that has been tapped to fit my spindle... 1" x 8 tpi.... may need to figure out a way to center the screw chuck...
__________________
Chuck
Tellico Plains, TN
Old 07-18-2017, 07:58 AM   #16 (permalink)
EBorraga's Avatar
Photos: 61
Default
So I drill a hole in the bottom of the chess piece. I plan on filling it later for weight. The jig fits perfectly in that. Then I use the screw to hold the blank to the jig. After that I mount it in my chuck and turn. The first size is so all of the bases are exactly the same size. I'll try and get some better pics for the next update.
__________________
Old 07-18-2017, 08:29 AM   #17 (permalink)
Photos: 0
Default
You will find that the smaller pieces with the same base size will be fine. HOWEVER, for general looks, the larger pieces will need bigger bases to remain standing even with the weights. Your design will be the most important thing. Trust your eye to tell you when it is right.
Best wishes
__________________
It's not "Having what you want"......it is "Wanting what you have".
"Don't go riding on that long black train."
stonepecker is offline   Reply With Quote Top
Old 07-18-2017, 07:52 PM   #18 (permalink)
EBorraga's Avatar
Photos: 61
Default
Update : 7/18
I was able to get in the shop after work and turn rook #2. It's not identical, but it will work for now.
The first 2 pics are the new rook.
Pics 3-9 are my step by step process starting from square to round.
20170718_190536.jpg   20170718_190626.jpg   20170718_190633.jpg   20170718_191608.jpg
__________________
Old 07-19-2017, 09:07 AM   #19 (permalink)
Photos: 1
Default
I wouldn't worry about pieces being identical... after all it is a hand made set and pieces will have some slight variables.... as long as they are close and identifiable, you're good to go... I have some blocks set aside to do a second set myself... may have to try your jig to see if it works better than the pen chuck.
__________________
Chuck
Tellico Plains, TN
Old 07-19-2017, 10:14 AM   #20 (permalink)
EBorraga's Avatar
Photos: 61
Default
The pen marks on my jig are so it goes in the chuck the same way everytime.
__________________
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
