Modified Spectraply shaving brush
See more from TattooedTurner
Surprise, Arizona
This was the first time I've turned spectraply. It's very easy to turn but for me, a pain to sand to a nice smooth finish. It takes a CA finish very nicely though. The one thing I don't care for is the "bubble" effect you get on the sides that run parallel with the dyed plys. I cut it apart & glued it back together to achieve a nice pinstripe effect almost all the way around, the exception being at the corners which you can see in the pics. I want to do this with a pen but I'll need to make a more accurate jig for cutting it. The brush hasn't been used so the knot hasn't bloomed out yet, it will look much better once it dies. I used a two band finest badger from a Chinese vendor on ebay. The knot was 23.5mm which works great with my 1" forstner bit & IX collet, but the glue bump above the plug was 28mm. I drilled the 1" hole, enlarged it with a parting tool, then drilled another hole through the cup into the handle & mounted it in a bottle stopper mandrel. It worked out great. C&C welcome, except for the pics. I know they stink, sorry.
View in Gallery
View in Gallery
View in Gallery
View in Gallery
View in Gallery
Surprise, Arizona
Thanks guys.
The best way to make the effect all the way around is to cut the blanks into equal staves and glue together.
I thought about doing that but have never made a stave anything. I decided to play it safe but unfortunately, I didn't get the total pinstripe effect I was looking for. If I make another I'll give it a go.
