Marbled Goose Egg Bottle Stopper
See more from Bob in SF
Bob in SF
San Francisco
Eggs on my mind.
Recalling some great times decorating eggs when my children were young...
Steps:
Goose egg blown out and sanitized.
Lathe-turned and hollowed the Zebrawood base, countersunk, Ruth Niles brass threaded insert epoxied into a 7/16" drill hole.
Sanded the base, then finished it with UV resin, hardened with a 250 watt 365 nanometers UV flood lamp 3" away, 30 seconds, while slowly hand-rotating the base (UV glasses, lots of ventillation).
Alum coated, then air dried the egg.
Marbled the egg using techniques which I've described in earlier posts.
Re-alumed the egg, air dried it again, marbled it a second time ( referred to as over marbling).
Egg dried x 24 hours.
Gently centered and epoxied the egg into the base on the lathe.
Brushed UV resin onto the egg while slowly rotating the base/egg.
Hardened the UV resin with the UV flood lamp (same as for the base).
Ruth Niles stopper attached.
attachment.php
attachment.php
Next version(s) will be carved eggs - stay tuned.
Best regards - Bob
pshrynk
Lake City, Minnesota
Very nice! How sturdy is the egg after all that work? Will it stand up to regular environmental bumps, or is it a "keep on the shelf and out of harm's way" sort of deal?
Bob in SF
San Francisco
Many thanks for kind comments!
Brian - The sturdiness question: UV resin is tough stuff - used for finshing lures, etc.
But just to be sure, I'll run a quick test and keep you posted...
attachment.php
More fun ahead - Bob:):bulgy-eyes::):eek:
magpens
Canada
Looks very nice, Bob !!!
But ... I am going to hafta think about this ... is the egg hard boiled ? Blown out ?
Bob in SF
San Francisco
Mal - The yolk is blown out of the egg, then the egg is sanitized with Clorox bleach, very well rinsed, then dried for a 5-7 days before use.
Duck, ostrich, and emu eggs are also fun.
I haven't carved eggs for a few decades, so the time is right - stay tuned.
Best regards - Bob
ajollydds
Colorado
Fabulous, Bob! I'm picturing the younger ones searching for plastic eggs filled with candy this weekend, while the adults are in another room searching for your bottle stoppers. Would make for a fun and lively hunt, Happy Easter!
Bob in SF
San Francisco
Heartfelt thanks Ankur!
Version 2.0 will be carved. This morning I airbrushed 5 layers of diverse colors onto this goose egg - should be fun to carve some low relief through the various colors, along with some through-and-through fenestration for additional "light play".
attachment.php
Also eager to work with some duck, emu, and ostrich eggs.
Emu eggs have a naturally dark green outer surface, teal mid-thickness, and white inner-thickness - should be nice for low relief gradated color tone carving.
- Bob
