Ok Chuck, here are few of my builds that are in my current quiver of go-to guitars.
The first is an ash tele body with a fender neck I stole off a basswood body fender Japan tele. Finish is urethane as I can't get nitro in Japan. It has had several changes of hardware and pickup combinations and I think I have settled on a "Nashville" layout using an original (yes ORIGINAL) '62 bridge pup and two hand wound reverse stagger pups made by the builder that does the custom shop Momose pickups (very nice). It's like a strat with snarl while still maintaining some great in-between sounds. The pickguard was a quick route to test out the pups and I never got around to cutting out another....meh, does the job.
The second is the mahogany strat I told you about. Now, this one has some mojo.....the neck is a delicious 57 RI Fender Japan that I took off a nice ....umm.....57 Reissue. The body is four part mahogany. Finish is minwax poly. Trem is standard Fender but with a steel trem block. Pups are Kinman AVN blues noiseless which I really like....which is good because they certainly are not cheap. I call this my David Gilmour (Pink Floyd) model as it just drips with meaty sweet tone and screams like a mofo when you dig in. BTW, the holes in the pick guard are for a GK2 guitar synth pup.
Anyway, just wanted to share.
Chris
