Wow Pat, you wasted no time, huh...?
Nice work my friend, I was just finishing a post reply about your larger bowl blank on its way, I look forwards to see what you will do with it, if you can find someone with a coring tool, you could made 2 or 3 bowls out of the large blank...!
I knew you needed to have a "fix" with Olive wood but, that bad...?:biggrin:
The blank was part of a crotch but the other half was shallow and full of holes, I wasn't sure how deep the heartwood was but obviously, the guts of it were removed as shavings and that is just how it is, unfortunately...!
I Know what you mean about the smell on your workshop, a very good reason to turn olive wood every so often...!:biggrin:
Cheers
George
