Couple mo bowls
See more from Cwalker935
Cwalker935
Richmond, Va
Another curly Ambrosia Maple Bowl and live Edge walnut. The Maple Bowl is around 7" in diameter and the walnut is 9" at its widest. I decided to add a stripe to the maple bowl. My wife does not like the stripe but I wanted to change it up a bit. I used a translucent dye. I wonder if it would look better darker or a different color. Constructive comments on the stripe welcomed. This bottom of the walnut bowl needs to be cleaned up, inscribed and finished.
mark james
IAP Collection, Curator
Medina, Ohio
The live-edge walnut is stunning.
The stripe does not do much for me; the bowl itself is beautiful, but for an accent, maybe a recess filled with one of the crushed stone inlays?
MRDucks2
Bristow, IN
I don't mind the stripe, but neither does it make me like the bowl better. I am a copper fan myself, so maybe a copper band or accent.
The walnut bowl is my favorite of the bowls presented in the last couple of months.
Lucky2
New Brunswick/ Canada
I like the look and design of each bowl, both are nice to look at. I can take or leave the red stripe, it neither adds nor takes away from the bowl. Personally, I would like to seethe stripe highlighted. I would like to see a burn line, above and below the coloring. I think burn lines, would make the strip stand out more.
Len
