Comford Ring Cores - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Other Things We Make
  Forgot Password
Other Things We Make Show off your bowls, stoppers, flatwork, etc.
Welcome to penturners.org!
Reply
Old 12-05-2017, 10:11 AM   #1 (permalink)
scotian12's Avatar
Photos: 0
Default Comford Ring Cores
Has anyone had experience with the new Artisan Comford Ring Cores from CSUSA? Does the thin veneer dry out and slit on the ring core. What is the best type of material to use? Thanks Darrell Esner
__________________
Darrell Eisner
www.scotianpens.com
Canada’s Largest Online Store of Wooden and Acrylic Pens
scotian12 is offline   Reply With Quote Top
Old 12-05-2017, 11:31 AM   #2 (permalink)
Mike@CSUSA's Avatar
Photos: 0
Default
Make sure your wood is dry and preferably stabilized if not an exotic. Spalted woods and burls are my favorites for rings. If you have questions turning them let me know. We also have a video on how to turn them: https://www.youtube.com/watch?v=IUJCkBRUKrY
Mike@CSUSA is offline   Reply With Quote Top
Old 12-05-2017, 06:54 PM   #3 (permalink)
scotian12's Avatar
Photos: 0
Default
Thank you Mike for your reply. Very good advice for an item that will get a lot of wear. Does anyone else have any experience with these ...ie how many sizes would you make or would you just take custom orders. How to handle sizing? Thanks Darrell
__________________
Darrell Eisner
www.scotianpens.com
Advertisement
Old 12-05-2017, 10:26 PM   #4 (permalink)
Photos: 1
Default
Here's a post I placed on the thread "Hollowing Rings" below:
I made the attached pair this weekend. In fact I made both of the twice. I drilled a series of Forstner bit holes in a waste board and tested the inserts for fit. I used the Forstner bit closest to the right size for each ring insert to bore the holes on the lathe after I turned the blank round. Then I took it off the lathe and used 80 grit sandpaper to get it to the final size I needed. I was using Purple Heart rather than one of the stabilized woods or synthetics. That's what the customer requested. One was a 10mm ring and the other a 3mm ring.
The first blank for the 3mm ring broke in half when I took it off the double sided tape. Let the glue dry for 48 hours then turned the rings. Turned the 10mm ring first. Had it almost down to size and was going to make one more tiny shaving pass when the blank shattered. Turned another one and glued it the insert and let it dry while I turned the 3mm ring. It turned easier than the 10mm ring for some reason. By the time the glue was dry, I was ready to turn the 10mm again. Customer was happy. Waiting to hear his wife's reaction. They are a surprise.
MTViper is offline   Reply With Quote Top
Old 12-06-2017, 04:41 PM   #5 (permalink)
scotian12's Avatar
Photos: 0
Default
Steve...Thank you very much for your reply. I guess caution is the word and light cuts. Its an interesting project and would make the receipant very happy. Darrell
__________________
Darrell Eisner
www.scotianpens.com
Old 12-06-2017, 05:04 PM   #6 (permalink)
Photos: 0
Default
If you need tutorials I have some, I make the 2 piece cores also see my Facebook page @ringandmandrel
J-D pens is offline   Reply With Quote Top
Old 12-06-2017, 07:43 PM   #7 (permalink)
Photos: 1
Default
J-D like your ring cores. Do you sell anywhere other than FB?
Old 12-07-2017, 09:02 AM   #8 (permalink)
Photos: 0
Default
Send me a pm
Old 12-07-2017, 10:19 AM   #9 (permalink)
fernhills's Avatar
Photos: 2
Default
I have been making, or i should say experimenting with them. I got a few cores in from CSUSA along with a couple of bushing. I made a acrylic one by CSUSA instructions, it went well but i got to much epoxy inside of the core and scratched it trying to get it off. They are not the two piece type. I want to wrap it around the core like you do with bentwood rings. I feel like that should solve the problem of having to have to use stabilized wood. I can make my own veneers. I made some bentwood rings and was very impressed on how strong they were for not much thicker than a wooden match stick. So with a metal core, they should be very strong. Carl
__________________
Carl, Hellertown,Pa
http://www.talltimbers.etsy.com
fernhills is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
