Cocobolo Humidor
See more from Halfcaff
Halfcaff
Pearland, Texas
I had some spare pieces of cocobolo I was trying to find something to do with so I came up with this. I made the frame with the spare pieces and then bought some beautiful cocobolo for the top. It is lined with Spanish cedar. It seals amazingly and holds the perfect 70% humidity for the cigars. It will hold around 25-30 cigars. I sanded it down to about 400 and then finished it with wipe-on poly. After plenty of coats of that I used some renaissance wax to put the final polish on it. I want to build a larger one now! Thanks for looking and any comments
Thanks everyone. The cost of the hardware was not too great. The barrel hinges were about $10 each and came from WC. The hydrometer was $8 and came from R. The humidification device (which is filled with little absorbent beads) was $8 and came from a local cigar shop. So cost of hardware was around $40.
The barrel hinges were nice. You just drill a hole. I have used other types of hinges on humidors but I like these the best.
Big cocobolo fan and that turned out great. What does the hardware cost (roughly?) Very nice work.....
Larry
I also made a pen out of the bit of wood left from the top. It is a navigator finished with CA and micro mesh.
