triw51
I started this splatted pecan bowl. Turned the outside and cut a tendon. When I turned it around I kept the tail stock up because it was heavy and still not quite balanced. As you can see in the pictures I hollowed around the center core. I had a catch and both the tendon and center core broke off and the bowl went flying.
I need to cut a new tendon the inside is not level on the bottom so I don't think a jam chuck would work. The jaws on the chuck I have open about 2 to 2.5 inches. Any suggestions?
Thanks in advance.
Thanks in advance.
