Bottle Stopper & Brass Pins
See more from SteveAxelrod
SteveAxelrod
Oldsmar, Florida
I love digging through the bargain wood bin at Woodcraft. I found a small piece of a dark wood that may be a variety of rosewood that was perfect for a bottle stopper. Unfortunately I discovered that the small checks on the end went about a third of the way through and I was forced to part it off and glue on a piece of spalted something (tamarind perhaps) that I also found in the bin. The spalted piece of wood had some of the same brown color as the rosewood and actually matched nicely. After turning the handle I decided the dark bottom was a little too long to suit my taste, but adding four brass pins in the middle broke it up and added a touch of class. Why is it that I've seen few others using pins as an enhancement?
Finished with O.B. Juice friction polish.
magpens
Canada
Steve, you seem to be the "Master of the Pin Enhancement" !!!!! . Well done again !!
... but you seem to be back to four ! :rolleyes::biggrin::tongue:
BTW, is that a titanium gold bottle stopper ?
oldtoolsniper
Iowa.
Finished with O.B. Juice friction polish.[/
Would you mind giving a rundown on how you do your pin work, or pointing me to the information?
Here is a knife handle I made from a dogs chew bone, I believe a cow shin bone. I made the pins that hold the scales on. I belt sand these to shape. Not sure they would hold up to turning.
