Barkless Cherry NE Bowl
See more from BernieW
BernieW
Goodland, Kansas, USA.
Here is a NE bowl I did but in the process of turning the bark flew off. So I just dyed the edge with india ink. Normally I burn them but decided to see how this would look. It is 8 1/2" at the widest and 2" deep at the shallowest part. It is finished with lacquer.
BernieW
Originally posted by ahoiberg
that's beautiful bernie... how did you reverse it to turn the base?
I use a donut chuck to reverse most bowls. To keep the edge up I use a PVC adapter (2 1/2" to 4") to hold the bowl edge up. When I put the bowl in the donut chuck I put the PVC with a mouse pad glued on the 4" end so it doesn't mark up the bowl. I put it on the inside of the bowl to hold it so the edges don't hit the donut chuck. Once clamped in the chuck I bring up the tailstock and put it in the mark it made while turning so it will be centered. Then I clamp it down tight and finish the bottom.
