White Alumilite Dye w/ Cactus Juice ??? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 01-15-2014, 05:44 PM   #1 (permalink)
RBcarving's Avatar
Photos: 0
Default White Alumilite Dye w/ Cactus Juice ???
I didn't want to make an experimental mess if someone has already tried this. Simply, has anyone used the white alumilite dye with cactus juice ??
And what were the results ??
Brad
RBcarving is offline   Reply With Quote Top
Old 01-15-2014, 05:45 PM   #2 (permalink)
Harley2001's Avatar
Photos: 0
Default
I have used green and works ok.not sure about white
Harley2001 is offline   Reply With Quote Top
Old 01-15-2014, 10:34 PM   #3 (permalink)
RBcarving's Avatar
Photos: 0
Default
Quote:
Yeah...Ive used most the standard colors. Just didn't know what the white would do...lighten the wood, make white swirlies ?? Just couldn't wrap my head around it. May just have to try a little and see what happens.
Thanks,
Brad
Advertisement
Old 01-16-2014, 10:49 AM   #4 (permalink)
Photos: 0
Default
Maybe give Curtis a shout out. He could probably help you out on this.
Silverado is offline   Reply With Quote Top
Old 01-16-2014, 02:02 PM   #5 (permalink)
Head Moderator
MesquiteMan's Avatar
Photos: 18
Default
White is most likely not going to do anything to the inside of the wood. It may make the outside white. The white dye is a pigment rather than a dye. Pigments are particles of the colorant and most likely will be too big to make it into the wood. The other colors are 100% liquid.
__________________
Curtis O. Seebeck
The original, affordable home stabilizing solution!
Now available exclusively from TurnTex...Alumilite Clear and White in 1 gallon kits (1/2 Gal A&B)
www.TurnTex.com
MesquiteMan is offline   Reply With Quote Top
Old 01-16-2014, 03:35 PM   #6 (permalink)
RBcarving's Avatar
Photos: 0
Default
Thanks Curtis. Appreciate the info.
Related Content
Reply
Bookmarks
Tags
alumilite , cactus juice , stabilizing
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
