West system epoxy - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 04-19-2017, 04:43 AM   #1 (permalink)
Photos: 0
Default West system epoxy
Does anyone use West System Epoxy?
I was wondering how clear it is?
andygorst is offline   Reply With Quote Top
Old 04-19-2017, 06:05 AM   #2 (permalink)
mark james's Avatar
Photos: 387
Default
I use 105 and 206 and 207. This is for gluing in veneer strips for accent rings.
The yellow cup is 2 part 5 minute epoxy, System Three that I have used for years to glue in my brass tubes.
The clear cup is the West System. Quite clear, essentially bubble free - simply sat in the cup, no pressure pot. These samples were done last year.
I have not used it for casting.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Old 04-19-2017, 08:33 AM   #3 (permalink)
longbeard's Avatar
Photos: 0
Default
I use 105 resin
207 special clear
Harry
__________________
any day above ground, is a good day
longbeard is offline   Reply With Quote Top
Advertisement
Old 04-19-2017, 08:45 AM   #4 (permalink)
lorbay's Avatar
Photos: 134
Default
Quote:
Originally Posted by longbeard View Post
I use 105 resin
207 special clear
Attachment 163017
Harry
What Harry said.
Lin
__________________
"If you come to a fork in the road Take It."
Yogi Berra.
lorbay is offline   Reply With Quote Top
Old 04-20-2017, 01:10 PM   #5 (permalink)
Photos: 0
Default
West system 105 and 207 it is then!
Thanks!
Old 04-20-2017, 02:55 PM   #6 (permalink)
jttheclockman's Avatar
Photos: 83
Default
Quote:
Thanks!
You did not say what you were using it for. That stuff gets expensive compared to poly resins. If you are just coating woods you may want to use 205 or 206 hardener. More yellow but it gives the wood a warmer tint than sterile clear.
Now epoxy has a tendency to yellow with time. I have never done a long term study with the 207 and maybe someone has and can report back. The true way to test is without anything in the blank because background colors can trick the eye. How noticeable a resin will yellow is hard to say with the thin thickness we work with. Just some things to keep in mind. One of these days I may just try that experiment if no one has done it before. Good luck and just wanted to point out other options.
__________________
John T.
jttheclockman is offline   Reply With Quote Top
Old 04-21-2017, 06:44 PM   #7 (permalink)
Photos: 0
Default
I used West Systems and loved the stuff. It seemed to be more forgiving than Alumilite as far as sticking to different surfaces. It is priced well over the other resins but it's not the same resin. It's not as brittle as P.R. and like I said it's more forgiving than Alumilite. It turns really easy and I never had a "Blow Out". It doesn't have the heat tolerance Alumilite has and doesn't quite have the shine the others do but it polishes very well. I never had a blank yellow but I always had trouble with the hardener yellowing in the can. It was good for a month and it wasn't noticeable in the blanks the second but the third month I didn't want to use it. I called the factory several times and they were nice and sent me a couple cans for free but I always had trouble. That was the only reason I switched to Alumilite slow.
Kenny Durrant is offline   Reply With Quote Top
Old 04-25-2017, 03:07 AM   #8 (permalink)
Photos: 0
Default
I am using it for clear castings for pens and other turning projects.
Alumilite is not readily available in my part of the world and I am looking to purchase about 4 liters at a time.
I am able to buy west system 105 from a local fiberglass supplier so this seemed like the easiest option for me.
I also believe that it has a longer 'open time' than PR (although I must admit I've never actually tried using PR)
Thanks for the help and advise.
Old 04-29-2017, 03:09 PM   #9 (permalink)
Tim'sTurnings's Avatar
Photos: 0
Default
Good luck if you try casting with epoxy. I have read some negative comments for this substance compared to PR and Alumilite for casting.
Tim.
__________________
Seven days without turning makes one weak.
Tim'sTurnings is offline   Reply With Quote Top
Old 05-02-2017, 04:06 AM   #10 (permalink)
Photos: 0
Default
Tell me more Tim!
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
