Warmup for the 2019 advanced casting contest.
greenmtnguy
Local Chapter Leader
Chester, Vermont, USA.
I have volunteered to run the 2019 advanced casting contest. Talking with Mike Redburn I am proposing the following rules: no CNC, no Laser, no 3D printers. Must be items you created or found, bought, etc. Items imbedded in any casting material of your choice. I would think out side of the box if you are considering Steampunk. Any other suggestions we should incorporate?
EBorraga
Passed Away July 17, 2022
Louisville, KY
Does it need to be a pen blank? Bottle stopper etc....
greenmtnguy
Good question Ernie,
Unless I am over ruled, I think it might get more casters involved.As far as I am concerned, I will leave that as an option. After all, it is a casting contest. Although I suspect, as pen turners we might be prejudiced towards pens. Go for it and the final vote will decide
EBorraga
Louisville, KY
Im in for sure!!
greenmtnguy
Entries will be limited to 1 per contest. However if you change your mind before the photos are posted, you can replace your choice. Once the photos are posted, that is your entry. Bottle stoppers and any other cast item will be allowed. Bear in mind that this is primarily a pen turning site, but feel free to post your choice of advanced casting.
