Sticky Alumilite - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 06-06-2018, 09:58 PM   #1 (permalink)
Photos: 0
Default Sticky Alumilite
I poured two ptown subbie Gisi style mold casts recently. I used Alumilite Clear for both. One was dyed with Alumilite white and red dyes. That one set and demolded correctly. The other was dyed with Alumilite Clear with white and yellow Alumilite dyes. After 36 hours in the pressure pot it is still sticky and gummy.
My question is can anyone tell me an easy way to remove this sticky Alumilite from the mold without damaging the mold?
I made sure the weight was correct on parts A and B and mixed well so I donít know why one cast correctly and the other didnít.
Any ideas?
DWalk is offline   Reply With Quote Top
Old 06-07-2018, 08:16 AM   #2 (permalink)
Sylvanite's Avatar
Photos: 35
Default
Put the mold in a warm (lowest temp) oven for an hour or so. The warmth will help the resin to harden. Then it will demold.
I hope that helps,
Eric
__________________
Eric Rasmussen
Rifle cartridges (bullet pen kits) for penturning available at:
http://www.bulletpenkits.com
Sylvanite is offline   Reply With Quote Top
Old 06-07-2018, 08:52 AM   #3 (permalink)
Photos: 0
Default
Thank you Eric. I wasn’t sure if I could heat a silocone mold that way. I’ll give this a shot
Advertisement
Old 06-07-2018, 09:56 PM   #4 (permalink)
Sylvanite's Avatar
Photos: 35
Default
Silicone molds should be stable at temperatures up to 400 degrees Fahrenheit.
I hope that helps,
Eric
__________________
Eric Rasmussen
Old 06-07-2018, 11:04 PM   #5 (permalink)
Photos: 0
Default
I heated it for 1 hour at 170*. It never hardened (it only hardened to a used chewing gum consistency) so I decided to just clean it out. I still don’t understand what happened to cause it to do that. But I thank you for your help Eric.
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
