Starting to dye and stabilize and could use some guidance - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 02-27-2014, 12:21 PM   #1 (permalink)
Photos: 0
Question Starting to dye and stabilize and could use some guidance
I'm going to be dyeing and stabilizing wood myself later today as soon as UPS shows up with my resin order and could use some guidance on dye to resin ratios. Using Cactus Juice resin and alumilite dye, trying for a nice mid to dark blue in Hemlock wood (Pine/Fir type wood)
Any advice on a good starting point for dye to resin mix to start with or guidance on how to go about figuring it out?
Thanks in advance!
Schroedc is offline   Reply With Quote Top
Old 02-27-2014, 01:37 PM   #2 (permalink)
Retired Head Moderator
MesquiteMan's Avatar
Photos: 18
Default
The thing to remember is that each species of wood will dye differently than the next. It all has to do with the concentration of resin you are able to get into the wood. Myself, I don't try to count drops or anything like that. I simply start with a quantity that I think will be enough to do the blanks I want to do. I then start adding dye and stirring. I add enough dye that, for blue, it looks black when I look into it. Keep in mind that your dyed Juice needs to be much darker than the finished blank. I then run a small test batch to completion and cut one blank down the center to see what the color looks like. If it is too dark, I add some virgin Juice. If it is not dark enough, I add more dye.
I am sorry I don't know of a better way to get more precise results but it is just impossible since each takes things differently. For example, spalted Pecan, which I can usually triple in weight, will take a less concentrated mix than hard maple.
__________________
Curtis O. Seebeck
The original, affordable home stabilizing solution!
Now available exclusively from TurnTex...Alumilite Clear and White in 1 gallon kits (1/2 Gal A&B)
www.TurnTex.com
MesquiteMan is offline   Reply With Quote Top
Old 03-05-2014, 12:06 AM   #3 (permalink)
mywoodshopca's Avatar
Location: Charlottetown, PEI Canada, Derby Kansas and Canyon Lake,Texas
Photos: 9
Default
Quote:
Great to know I got a slab from someone recently.. Maybe I should send it home with Jim so he can use his juice up fast lol
mywoodshopca is offline   Reply With Quote Top
Advertisement
Related Content
Reply
Bookmarks
Tags
blue , dye , resin , stabilizing
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
