About how long at 200 degrees, do you need to dry wood that has a moisture reading from 8 to 12%. I've baked all my woods for about 24 hours at 200º Denser woods vs softer woods but about how long? Also, am I going to **** off the wife if I use the kitchen oven to dry the wood? probably not. but you will if you use the kitchen oven to heat cure the Cactus Juice and it leaks out and spills in the oven. I have'nt noticed any odor from drying the wood but my schnoze might not be functioning correctly.
Can I put a kitchen cutting board mold inside the vac box? I made a pen blank sized mold and would like to put a piece of wood with boocoo voids in it and then use a craftin craft PR mixed with mica powder to create one of those really cool looking pen blanks.
BTW, curtis, bought one of those oven thermos so I know exactly where 200 degrees is now...just below the 150 setting....(made in china, I guess)
I purchased a cheap toaster oven at Walmart onsale and it works great. I would not use an oven that I intended to eat from. I use much lower temps for actually drying woods I use like 125 for so. I use a thermometer so I can be sure about what I am doing. I am not sure what temp will or could cause wood to combust that is why I use lower temps. The flash point for most wood is 525° F so as long as it is not touching the element, it will not burn at low temps such as 200° I only cook for about 1 hour when I am done stabilizing though! This is fine if you are doing pen blanks. However, if you start doing larger pieces or more pieces at a time, you cure time will go up. One hour is NOT a good blanket recommendation since if you take it out and let it cool down and find that it has not cured, you have just wasted that piece of wood since it will not cure properly the second time. Remember, it takes 6-8 minutes at 200° F to polymerize the resin. The issue is, however, that you must get the internal temp of the wood up to 200° and that takes some time. The amount of time is dependent on thickness of the wood, how much wood, and even the density of the wood. I would rather see folks be on the safe side and cook for 2 hours than to see wasted wood! I also use a thermometer when doing that. I usually don't use tin foil. My oven has a catch basin so the Juice doesn't get to the burner. Just my way..
having done the process once (not drying the wood all the way and not usuing a dye) can I get a do over? Can I dry the wood some more, resink it in some resin mixed with dye and vac it/bake it??? or do I have some more outside firewood?
My comments in red below:
Sorry Curtis I have been cooking for about an hour all along and it works for me. I don't use any tin foil maybe that is why but an hour seem to get it done for me. I do check to make sure everything is solid. I am getting ready to get my 3rd gallon so it's not like I have not been cooking a bit.
