Stabilizing Spectraply with Cactus Juice
Silverado
Has anyone tried to Stabilize Spectraply with Cactus Juice, if so does it work well?
KenV
Juneau, Alaska.
Terry Q writes that he stabilizes his spectra ply blanks on a regular basis.
I will be doing some this fall so the spectraply will hold better detail.
Silverado
Thanks Ken. I saw that but would like some other feedback if anyone else has done it.
terry q
301 E. Court St. Roanoke, Illinois, USA.
I've stabilized some and had the colors run between dark layers to light layers. Anyone else experience this?
Rick I do find the colors are a little muted in the cross grain after stabilizing. Doesn't seem to affect the long grain. Is this caused by colors running together? Probably.
Edward Cypher
Denver, Colorado
I stabilize all my spectraply, it darkens a little and some colors run, some do not. I do a lot of segmenting Gisi style and after putting in all that work it is a bummer when the spectraply breaks and chunks come out. That happened the first time and I have stabilized since then. Did not happen with diamond wood.
