Stabilizing after drying via DNA
Jim Dent
Granton, WI
Anyone have any experience stabilizing wood with Cactus Juice, after the wood has been dried using denatured alcohol?
Justturnin
Houston, Tx
I would invest in a small scale. I got one from HF for about $20 and dont know how I did w/out. Just weigh the wood every few days and when you have several reading at the same weight you are dry. A Moisture Meter will only give you surface for the most part unless you cut into the wood and take a reading then.
