Stabilization Help Question - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Blank Making > Casting & Stabilization
  Forgot Password
Casting & Stabilization Making your own blanks & stabilizing wood blanks.
Welcome to penturners.org!
Reply
Old 11-04-2017, 12:47 PM   #1 (permalink)
Photos: 0
Default Stabilization Help Question
Hello -
I am new to pen turning and Wood Stabilization - learning a lot from everyone here - Thank You!
I have stabilized spalted pen blanks and noticed that at the beginning the wood floats and upon completion of the vacuum process the wood no longer floats it sinks to the bottom of the juice.
Here is my question - I have just stabilized my first batch of Maple Burl and when complete with the vacuum process the wood still floats. It was in the vacuum chamber for over 3 hours and there were a very very slight intermittent bubble or two, not much different than I have seen with my limited experience. Is this normal?
Thanks,
Pete
pjkoths is offline   Reply With Quote Top
Old 11-04-2017, 12:48 PM   #2 (permalink)
Photos: 0
Default
Let it soak. Is it completely submerged still?
Camardelle is offline   Reply With Quote Top
Old 11-04-2017, 12:52 PM   #3 (permalink)
Photos: 0
Default
Quote:
Yes they are still submerged with weights since I removed them from the vacuum chamber about 13 hours ago.
Advertisement
Old 11-04-2017, 12:54 PM   #4 (permalink)
Photos: 0
Default
If they’re still submerged give them some time. I was getting tiny bubbles a couple days ago from some maple. Three pieces sank and one floated like a dead goldfish till the next morning. They’re still soaking.
Old 11-04-2017, 01:03 PM   #5 (permalink)
Photos: 0
Default
And for the record I don't claim to be the definitive authority on this. There are many here and elsewhere who surpass my knowledge. This is just based on my experience. I hope it helped.
Sent from my iPad using Tapatalk
Old 11-04-2017, 01:08 PM   #6 (permalink)
Photos: 0
Default
Thank you.
I am just wondering if putting the wood back under vacuum would do any good?
Old 11-04-2017, 01:09 PM   #7 (permalink)
Photos: 0
Default
Pull a vacuum on it. It can’t hurt it. Report back.
Old 11-04-2017, 04:57 PM   #8 (permalink)
Tim'sTurnings's Avatar
Photos: 0
Default
I would put them back into the vacuum chamber and make sure your vacuum pump is running the whole time you have them in there at full vacuum. My pieces of spalted pecan pen blanks took a lot more time than you stated for yours. I keep mine in vacuum until I see NO bubbles, but I don't have a lot of experience either. But I do know to make sure that the vacuum pump is running the whole time your pieces are in there and, as you are doing, let them soak when you take them out. They should all sink when full of the stabilizing solution, in my opinion. Good luck.
Tim.
__________________
Seven days without turning makes one weak.
Tim'sTurnings is offline   Reply With Quote Top
Old 11-07-2017, 10:41 AM   #9 (permalink)
Photos: 0
Default
Thank you for all your help.
I am posting my results . . . I put the blanks back in the vacuum chamber again for a little over 24 hours with the vacuum pump running the entire time, there was no bubbling at the end of this time. I let the wood soak weighted another 24 hours. When I removed the weight all the blanks floated. After all that I did not expect them to float.
I cooked them and they came out just like other blanks I have done. I will turn one and see what happens.
Thanks,
Pete
Old 11-07-2017, 06:41 PM   #10 (permalink)
Photos: 0
Default
I have had this happen with white oak. Three days under vacuum and there were still some small bubbles. I have not noticed any difference in the final product and the CJ looks to have penetrated throughout the blanks.
PatrickR is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
maple burl , stabilized
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
